b16 cam bolts KEEP BREAKING!!!
Old Sep 1, 2009 | 10:12 PM
:::SIRll_EJ1:::'s Avatar
Default b16 cam bolts KEEP BREAKING!!!
So I have a B16a2 that i've been building onto for about a year. I've finally come down to the point where I have to torque the cam plates down(theres about 18 bolts total) I Know the torque spec is 20lbs and I am using the proper torque sequence, my torque wrench is brand new and I also oiled the threads. Iv'e also replaced all of them with new OEM bolts from honda Twice. the only thing I can think of wrong is that i'm using a 1/2 to 3/8 adapter on the torque wrench. Is this wrong???
Thanks in advance,
-Ray
Old Sep 1, 2009 | 11:03 PM
wilham320's Avatar
Default Re: b16 cam bolts KEEP BREAKING!!!
just because your torque wrench is new, does mean its properly calibrated. If it was droped, left at a high torque setting when stored, used as a breaker bar, ect it can loose its calibration. Also most torque wrenches are not accurate at bottom and top 10%... meaning your torque wrench needs to be in a middle setting for it to be more accurate, if 20 is the lowest setting, find a smaller torque wrench. Which it sounds like a big one if your using an adapter.
Old Sep 1, 2009 | 11:49 PM
Do u know how it can be re-calibrated???
Old Sep 2, 2009 | 12:35 AM
im a monster hehe's Avatar
Borrow one of your friends to see if yours is right or wrong.
Old Sep 2, 2009 | 03:28 AM
JDogg's Avatar
20ft/lbs is too high, you will break used bolts
tq em to 18, make sure to use a very SLOW smooth motion. stop at the first sign of a click.
you should not be using a 1/2 inch torque wrench for this, go buy a 3/8drive torque wrench. adapters and extensions dont make any difference
Old Sep 2, 2009 | 03:48 AM
REEMB18C1's Avatar
loosin the valve adjust ment up and check to see if the bolts are strecthed new bolts are a dollar each from honda just get new ones
Old Sep 2, 2009 | 05:38 AM
Furyof4's Avatar
^What he said. I never torque them to 20lbs anymore. same with trans case bolts.
Old Sep 2, 2009 | 07:13 AM
.Manny.'s Avatar
Touching My Member
I always torque to 18 and use a 3/8" drive wrench
Old Sep 2, 2009 | 10:34 AM
wilham320's Avatar
Most big cities have a business that can calibrate tools, call a snap-on/matco/mac tool rep one of them should know, or try local machine shops, and check the phone book.
What is the low/high settings on yours?
Old Sep 2, 2009 | 10:38 AM
JDogg's Avatar
how much did you spend on the torque wrench? if it was less than $100bux, just go buy a new one, its not worth the hassle, plus you need a 3/8drive torque wrench anyway
Old Sep 3, 2009 | 02:43 PM
8zero8's Avatar
unless its an electronic wrench i think 20 lbs on a half inch is barely noticable.. a 3/8 would do you better.
:::SIRll_EJ1:::
Sep 2, 2009 03:05 AM
hspoon
Nov 24, 2007 03:57 PM
m00nr0ck Si
Jan 1, 2006 11:39 AM
Modifiedinteg
Dec 14, 2003 10:06 PM
denshu
Nov 14, 2003 07:47 PM
