torque specs
Old Nov 24, 2007 | 10:28 AM
hspoon's Avatar
Default torque specs
wat are the torque specs for the 12mm bolsta that goes in top of the cams...???
the cam holders?
Old Nov 24, 2007 | 10:46 AM
94 IntegraLS's Avatar
Default Re: torque specs (hspoon)
It's 7.2 lbs/ft for the LS cam holder bolts but im not sure if its the same with the GSR's.
*Edit* if you have a GSR this will help you out http://www.team-integra.net/se...D=613
Old Nov 24, 2007 | 01:34 PM
AWD Terror's Avatar
Default Re: torque specs (94 IntegraLS)
The GS-R is a higher torque spec.
I think like 15 or so.
You should be able to tell how much torque the bolt can hold.
Old Nov 24, 2007 | 03:57 PM
IN VTEC's Avatar
20lb*ft for the M8x1.25 bolts. 7.2lb*ft for the M6x1.00 bolts. Work your way from inside-out when torquing them down.
Civic483973
Jun 21, 2010 11:33 AM
jp1
Feb 14, 2006 04:55 PM
I got a honda
Oct 19, 2005 08:06 PM
Modifiedinteg
Dec 14, 2003 10:06 PM
