takata harness
any one know how to install the takata harness on a 00 civic si? with drilling it? or do you have too. I dont want the ones that go to the back seat. is the easiest way with a harness bar?
the bar bolts to the side of the pillars. where the sealts belt slider dealy is?
the pasgners in the back will have negative safety. and the harnes will bolt right to where the seat brackets are...if you have a harness and bar but no roll cage...i hope you dont roll over..you will die, because the cage, harness and upright seat is a system.
stock seat, belts. is a seperate system, mix them and you peeing in the wind with your safety
It will go over the bar and then what? Im not trying to bolt them to my baclseats but to the harness bar. I just dont know how. Do i fold them?
http://www.takataracingproducts.com/guide.html Very BAD how-to from TAKATA
http://www.schrothracing.com/sdocs/2...structions.pdf Great guide from SCHROTH
Now for the real question. It ssems you are worried about keeping your back seats. When have you ever seen anyone driving in a vehicle that requires use of a competition harness with passengers in the back seat ? You don't want to drill holes to mount the thing correctly if that is required. Save your family and friends the grief of having to come identify your body, or that of your friends in the back seat that got a face full of harness bar, and do it right or don't do it at all. On the bright side, maybe all the hard parkers will give you props if they pick out that mad tizite JDM casket for you.
streetsold6teeny8
30
Aug 29, 2009 02:49 PM
boosted91crx
16
Apr 28, 2009 08:57 PM
