How do u bleed the clutch ??
Old Aug 31, 2009 | 06:58 PM
miguey310's Avatar
Default How do u bleed the clutch ??
Old Aug 31, 2009 | 07:55 PM
miguey310's Avatar
Default Re: How do u bleed the clutch ??
ttt
Old Aug 31, 2009 | 08:02 PM
!IShockedURMom!'s Avatar
What kind of car and kind of motor?
Old Aug 31, 2009 | 08:22 PM
miguey310's Avatar
it's a 90 si with zc sohc swap
Old Aug 31, 2009 | 08:29 PM
grog's Avatar
well you would know if you had a hydrolic clutch (in an EF). if your EF/ED is stock then you have a cable clutch, which has a plastic adjuster nut above the clutch arm. there is nothing to bleed for the clutch in these cars,
Old Aug 31, 2009 | 08:31 PM
EL Vap133's Avatar
You don't have a hydro tranny so no need to bleed the clutch.
Old Aug 31, 2009 | 08:48 PM
miguey310's Avatar
how do u fix the squeaky clutch ??
Old Sep 1, 2009 | 07:49 AM
mjfubar101's Avatar
Depends if its the clutch or just the pedal. My pedal always squeaked...
Old Sep 1, 2009 | 10:30 AM
4drEF's Avatar
Keyboard Humorist
Squeaky clutch pedal should have you examining the pedal assembly.
It's somewhat common for the assembly to crack and break.
Old Sep 1, 2009 | 10:34 AM
8VEYBEYB's Avatar
if it squeaks at idle outside the car not by the pedal sounds like it could the the TOB (throw-out-bearing)
Old Sep 1, 2009 | 10:41 AM
Eighty-Nyne's Avatar
Tons and tons of lithium grease slapped up on the pedal assembly.
Old Sep 1, 2009 | 11:18 AM
sh!ft's Avatar
Who the fack changed my title?!
wd40
Old Sep 1, 2009 | 03:03 PM
miguey310's Avatar
thanks everybody ur ur help
Old Sep 1, 2009 | 06:00 PM
efsex's Avatar
PB blaster fixes that
right on the cable
just like a pedal bikes brakes hahah
i love this old technology
Old Sep 1, 2009 | 06:02 PM
efsex's Avatar
i dont think throw outs squeak when they go
[ej]Jonathan
Mar 23, 2009 11:45 AM
MniMeHatch89
Jun 13, 2006 10:48 PM
FLCivic
Jun 30, 2004 03:48 PM
tnsxsear1
May 18, 2004 09:56 AM
KooK
Jul 11, 2002 03:28 AM
