Sticky Clutch
Old Aug 29, 2009 | 12:31 PM
zach1288's Avatar
Default Sticky Clutch
I just started noticing that my clutch pedal seems "sticky". It will engage right off the floor sometimes and seems to stick for a second? The clutch assembly only has 8k miles on it or so.
Old Aug 29, 2009 | 12:53 PM
forcefedferio's Avatar
Default Re: Sticky Clutch
sounds like a bad clutch master cylinder.
look under your dash where the plunger comes through the firewall connects to the clutch pedal, if its wet there is your problem.
cost is approx $35 depending on what parts store you choose.
Old Aug 29, 2009 | 12:55 PM
zach1288's Avatar
Thanks, i will check this out tonight.
Old Aug 31, 2009 | 02:58 PM
zach1288's Avatar
I checked around the master cylinder and around the pedal and I could not find and fluid?
Old Aug 31, 2009 | 04:53 PM
likecatnipp's Avatar
bleed the clutch again
Old Aug 31, 2009 | 07:24 PM
this ^ and also check for leaks at the slave cylinder too.
Old Sep 1, 2009 | 04:18 AM
tercel95's Avatar
It is common in these cars for the slave or master cylinder to fail... In my experience though its more likely to be the slave than the master...
Old Sep 1, 2009 | 05:37 AM
Crossbreeder's Avatar
Agreed, check the slave cylinder, and this problem could be as dumb as your clutch pedal spring.
Old Sep 1, 2009 | 05:43 AM
92ehatch's Avatar
does it make a creaking noise when you push the pedal down?
if so that could be the slave cylinder.
or if you replaced the clutch, did you put some high temp grease on the input shaft? and where the slave cylinder touches the fork?
honda recommends to grease there (urea high temp grease is what i use)
Old Jan 21, 2010 | 03:16 PM
zach1288's Avatar
There is no leaking anywhere. It only sticks once and awhile. This sounds weird but it never sticks while in a straight line. I only notice it happening when turning and starting out like in a drive threw?
PaulMc
May 18, 2014 05:04 PM
vinceg143
Sep 9, 2008 07:14 AM
crxricer66
Dec 1, 2007 07:58 PM
RDAYA0
Dec 14, 2006 05:31 PM
FuNkDrSpOt
Oct 10, 2006 09:48 PM
