Fluctuating temp gauge
Old Aug 26, 2002 | 03:04 PM
speedymon's Avatar
Default Fluctuating temp gauge
Both my temp gauges(factory and aftermarket) fluctuate while i'm driving. It drops about 15 degrees and then bounces back up. Could the cause be air in the system?
Old Aug 26, 2002 | 03:11 PM
Spade's Avatar
Default Re: Fluctuating temp gauge (speedymon)
Does your radiator fan turn on when the temps go down?
Old Aug 26, 2002 | 03:15 PM
sgT's Avatar
sgT
did you move the factory sender?
Old Aug 26, 2002 | 03:20 PM
speedymon's Avatar
Default Re: Fluctuating temp gauge (sgT)
No i did not
[Modified by speedymon, 7:20 PM 8/26/2002]
Old Aug 26, 2002 | 03:23 PM
sgT's Avatar
sgT
where did you install the aftermarket sender
Old Aug 26, 2002 | 03:37 PM
speedymon's Avatar
water neck at the upper radiator hose and head.
Old Aug 27, 2002 | 10:02 AM
speedymon's Avatar
ttt
Old Aug 27, 2002 | 10:33 AM
Civic1992DX's Avatar
Once I has something different happening. Autometer water temp. gauge had a sender right in the upper radiator hose. One day while driving, I noticed that when I leave it in neutral, the stock Honda gauge would climb up & Autometer would dive right away. That's @ idling RPMs only. As soon as I'd step at least to 1000 RPM, the stock gauge would start coming down & Autometer's would get up to 200+. I realized that it's my water pump is going: @ low RPM, the pressure is so low that the water wouldn't even get in upper radiator hose, so Autometer's gauge would dive. In the meanwhile, stock sensor sits lower in the head, so because of the lack of circulation temp. would raise & that's exactly why stock one was raising.
I replaced the water pump & it's fine now.
Autometer always flunctuates between 190 & 220F (depending on driving style) but stock gauge is always in the middle unless the temp raises above 235F (in EG).
Yuri K
Old Aug 27, 2002 | 10:48 AM
Perfectionist's Avatar
Although it's not a drastic change in temp, your t-stat may be getting sticky. I would go with OEM if you replace it.
Old Aug 28, 2002 | 01:16 PM
speedymon's Avatar
Default Re: Fluctuating temp gauge (Perfectionist)
Hmmmmm you guys don't think i have air in the system?
Andrew Sutherland
Jun 29, 2008 08:55 AM
AntMan401
May 25, 2007 08:36 PM
project civic
Mar 16, 2006 09:46 AM
Mikey
Jan 8, 2005 08:03 AM
ten_30
May 26, 2002 09:50 AM
