FITV Problems
Old Aug 28, 2009 | 05:57 AM
scottmog's Avatar
Default FITV Problems
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/check-oil-light-car-dying-2635603/
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/how-fix-your-idleing-woes-fitv-iacv-2153910/
car dying after long drives when warmed up at idle. question i have, do zc singles have a FITV??? I only have the top whole in my throttle body. I dont have a lower hole.
Old Aug 28, 2009 | 06:36 AM
dephtone's Avatar
Default Re: FITV Problems
If you don't have the lower hole inside the Throttle body, you don't have a FITV.
FITV usually only come on obd1 mani's.
Are you throwing any codes?
Old Aug 28, 2009 | 06:44 AM
scottmog's Avatar
no, no codes at all. this is really pissing me off. my problem so closely resemples a problem with the fitv. i hate when my car dies at stop lights lol ><
Old Aug 28, 2009 | 06:49 AM
dephtone's Avatar
FITV usually causes idle surging not dying at stop signs.
It only dies when it's up to temp not when it's cold?
Old Aug 28, 2009 | 07:24 AM
scottmog's Avatar
exactly, ive always had a little bit of a bad idle. the idle surge gets so bad and the rpms get so low that the engine turns off. i honestly think that is the problem unlessu have any other ideas
Old Aug 28, 2009 | 07:31 AM
dephtone's Avatar
Have the car running, and then unplug the IACV if the car dies, you know the IACV isn't working properly, it should have a real fast surge idle if it's working properly. Should fluctuate ~250-500 rpm max when it's unplugged.
Have you removed the Idle Air control valve and cleaned out the little screen?
Have you tried to screw the idle screw out raising the idle a little bit?
Old Aug 28, 2009 | 08:06 AM
scottmog's Avatar
Interesting, never knew that. Ill try it out at break, im at work right now lol ><
I cleaned the hell out of the IACV about 6 months ago.
No i havnt tryed screwing the idle to raise it.
Old Aug 28, 2009 | 08:19 AM
dephtone's Avatar
Like if you are sitting idle does the car just idle low and then die or does it go up and down and then die?
Raising the idle might help if the car idles to low and it just ends up dying, maybe it won't get that low with the idle screw adjusted up. That's what I would check anyways.
Old Aug 28, 2009 | 11:07 AM
scottmog's Avatar
Bump since im still open to options and opinions
Old Aug 29, 2009 | 05:48 AM
scottmog's Avatar
Bump
philep_cb7_91
Feb 21, 2010 11:28 AM
twentyhurtz
Dec 5, 2008 07:30 PM
gutted-dx
Dec 18, 2005 09:08 PM
V-Thang
Acura TL, RL & ZDX
Feb 24, 2004 02:10 PM
Ideal
Aug 22, 2002 08:51 PM
