loud noise and loss of power under load
Hey everyone, I've been trying to solve this problem with no luck. I have a completely stock 2000 civic (automatic) that is having issues under load. It feels like it has lost a lot of power and makes a loud sound thats almost sounds like air being forced out of a tube under load. Here is what I know:
- The idle is smooth, does not fluctuate and I could not find any air leaks.
- This problem just started happening this morning, it has been running fine up until now.
- I would say anything past 2k with more than 40-50% load makes the noise occur.
- A/c is still cold
- Trans/oil/coolant levels all look good and at the proper levels
- The car is not beat on, it is a daily driver to and from work
Does anyone have any suggestions?
- A/c is still cold
A clogged filter can cause your car not to run at all, stall out when stopping, rough idle, no power, loss of power, Any of the above and several others on top of causing IACV Damage.
Change your air filter every 15,000 miles or buy a K&N and wash it every oil change.
Yeah 10,000 miles sound about right, but i figure "Hell im waiting on oil to drain, let me clean filter"
if you jumped timing, you'd know it, you wouldnt get it very far with your valves intact
The pinging could be a bad valve, Bad valve lash, etc. You may have even bent a valve or broken one, I'd change air filter first, if that doesnt, re-adjust your valve lash. if that doesnt work... You obviously need to take it to a professional i wouldnt advise you to try it yourself.
djowen
10
Apr 20, 2011 11:56 PM
xandrake
Feb 7, 2007 08:12 AM
pinecone
10
Mar 26, 2006 08:27 AM
