broke ecu pin for o2 sensor help please
Old Aug 27, 2009 | 05:39 AM
Luke G.'s Avatar
Default broke ecu pin for o2 sensor help please
im doing a b18c jdm swap in my 93 cx hatch. I am wiring up the 4 wire o2 and on the ecu pins i ripped the wire from it. Then trying to get that out i snapped another piece of the pin off so there is only like half left, is there any way to deal with this? its driving me nuts and wasting time on me doing this motor swap.
Old Aug 27, 2009 | 07:41 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: broke ecu pin for o2 sensor help please
you could get a new ecu. or like what i did. i pulled out an ecu plug and it yanked out the whole vtec pin. but my friend chips ecus and just soldered a new pin in.
Old Aug 27, 2009 | 07:55 AM
Luke G.'s Avatar
no this is on one of the plugs going into the ecu, not the ecu itself
Old Aug 27, 2009 | 08:01 AM
I'm not Rick!
do this, run a new wire
Old Aug 27, 2009 | 08:02 AM
Luke G.'s Avatar
i tried that but ripped the wire out from the pin, then when trying to remove the little metal pin it broke in half so there is half still in the connector+
Old Aug 27, 2009 | 08:07 AM
I'm not Rick!
dang...then do this...(i had to do this several times from the same thing or melting plugs)
get a new plastic plug from the junk yard(with wires that you cut from the harness)
Old Aug 27, 2009 | 08:09 AM
Luke G.'s Avatar
thats the only thing i could think of too, though i hate to have to do all that
Old Aug 27, 2009 | 08:13 AM
I'm not Rick!
yeah..i did it 4x now. as long as you got a super good ecu pin tool. its easy. just do 1 wire at a time
Old Aug 27, 2009 | 08:36 AM
Luke G.'s Avatar
where can i buy the tool from?
Old Aug 27, 2009 | 08:40 AM
I'm not Rick!
you cant. that in th epic is just a tiny eyeglasses screwdriver. i had a cawter pin.
paper clips dont work they bend too easy
Old Aug 27, 2009 | 08:46 AM
Luke G.'s Avatar
oh alright i'll pick one up, thanks for the help.
Old Aug 28, 2009 | 06:03 AM
Luke G.'s Avatar
would i be able to just cut and splice the wires in instead of potentially ruining the new connector?
Old Aug 28, 2009 | 06:07 AM
I'm not Rick!
yeah you can cut and connect the wires but. thats realy crappy especialy down the road if you dont solder and heat shrink them. pulling pins is easy. practice on a crappy plug and itl take you 2 minutes to replace all the pins in a plug. 1 at a time
Old Aug 28, 2009 | 06:30 AM
Luke G.'s Avatar
alright thanks.
suproman
Dec 1, 2010 07:55 PM
turboef90
Dec 25, 2007 10:00 AM
silverboost
Oct 17, 2005 11:21 AM
SlammedHatch90
Dec 29, 2002 01:21 PM
