Need Help w/ 1998 Honda Civic LX speedometer
Old Aug 26, 2009 | 09:17 PM
pang_yeng's Avatar
Icon3 Need Help w/ 1998 Honda Civic LX speedometer
Hey everyone,
It seems like my speedometer has stopped working on me. I was driving to work on the highway when my speedometer just dropped from 60 mph to 0 mph. It's also been jumping up and down when I'm driving. It seems like the fuse is still good. What could be causing the speedometer to not work?? Any suggestions?:
**The CEL is on
Old Aug 26, 2009 | 09:19 PM
Former User's Avatar
Default Re: Need Help w/ 1998 Honda Civic LX speedometer
Is the CEL on?
Double check fuse #15 under the dash.
Old Aug 26, 2009 | 09:35 PM
pang_yeng's Avatar
yes, the CEL is on. as for the fuse, i will have to check
Old Aug 26, 2009 | 09:36 PM
pang_yeng's Avatar
actually..i've checked all the fuse and they're fine. so what could it be?
Old Aug 26, 2009 | 09:39 PM
Check whether fuse 15 is or is not blown. Either swap in a known good fuse or test with a multimeter.
Click here to learn how to pull the CEL codes.
Old Aug 27, 2009 | 11:41 AM
slayerfromhell212's Avatar
it might be your speedmeter im not sure how its called but it goes on your tranny its a sensor
Old Aug 28, 2009 | 09:22 PM
pang_yeng's Avatar
I've tested it, and it isn't the fuse 15 or any other fuse. could it be the speed sensor? if so, how much does it cost to buy one?
Old Aug 28, 2009 | 11:57 PM
EL Vap133's Avatar
Check to see if the VSS is on tight at the top of the tranny.
Old Sep 2, 2009 | 09:47 PM
pang_yeng's Avatar
yupp, the Vss is tight
Old Sep 2, 2009 | 11:59 PM
Chermka's Avatar
I had the same problem on my 98 civic. Ended up buying speedometer from junk yard ($10). Now the problem is gone!
Old Sep 3, 2009 | 06:23 AM
What are the CEL codes?
Old Sep 3, 2009 | 09:51 PM
pang_yeng's Avatar
These are the codes that came up when I took the car to autozone
CODES:
P0141
P1298
P0135
PO500
But how would I know which part to start with? I don't want to waste a lot of money buying a part and find out it's not the part I need to fix my speedometer.
Old Sep 3, 2009 | 09:57 PM
CODES:
P0141 - secondary O2 sensor heater
P1298 - ELD
P0135 - primary O2 sensor heater
PO500 - VSS
Those codes STRONGLY suggest that 7.5A fuse #15 under the dash is blown. Are you sure you have tested this fuse?
Read this TSB.
Old Sep 4, 2009 | 03:33 PM
pang_yeng's Avatar
[QUOTE=RonJ@HT;39856851]CODES:
P1298 - ELD
PO500 - VSS
Read this TSB.
well, i checked today and replaced the 7.5 fuse. the speedometer started working again, but the CEL is still on. what else could be wrong?
By the way, I'm unable to open the TSB tab.
Last edited by pang_yeng; Sep 6, 2009 at 07:15 PM. Reason: thank you...the CEL is not on no more
Old Sep 4, 2009 | 03:57 PM
Kista20's Avatar
since you replaced the fuse did you reset the cel? the easiest way to reset it is to unhook the battery for 10-15 min that will clear the light.
Old Sep 4, 2009 | 04:24 PM
The TSB link downloads a PDF version of the TSB to your computer.
Fuse 15 blows due to a short in the wire harness located behind the intake manifold. Therefore, regularly check whether the fuse has again blown. Reset the ECU as mentioned. Ultimately, the short must be repaired to fix the problem. Read the TSB for details.
Old Sep 4, 2009 | 04:27 PM
23LX23's Avatar
Had the same problem in my 98 lx, im going to check tomorro...
Old Sep 9, 2009 | 04:39 PM
pang_yeng's Avatar
Thanks everyone who helped me find the problem to my car. My uncle did something with the fuse and now the speedometer is working fine and the CEL is not on anymore.
Old Nov 23, 2011 | 12:57 PM
domster60's Avatar
Have the same problem with my car...check fuse 15 and it is good..cell on but code is for bad oxygen sensor..how can I check if VSS is good..Thanks...
Old Nov 23, 2011 | 10:46 PM
pkthundaaar's Avatar
I have the same problem with my Civic right now. Should I check the fuse as well?
Old Nov 24, 2011 | 05:21 AM
HondaPartsHero's Avatar
Technical Hero
http://techauto.awardspace.com/vss.html
Old Nov 24, 2011 | 05:52 AM
domster60's Avatar
HondaPartsHero..thanks for the thread..Hopefully its the VSS..much cheaper and easier to change...
parisz47
Apr 11, 2017 05:02 AM
W95civicEXcoupe
Mar 2, 2015 10:25 AM
Devious951
10
Aug 29, 2009 10:22 AM
pacey
12
Aug 18, 2009 11:24 PM
Luiz_aka29
12
Aug 15, 2009 08:56 PM
