Help DA cluster in USDM 91 Si
Old Aug 26, 2009 | 04:49 PM
patwitahonda's Avatar
Icon6 Help DA cluster in USDM 91 Si
I did a EF to DA cluster swap today and followed the pinouts correctly.
The problem is my turn signals don't work at all.
It doesn't light up at all on the cluster.
Fuses are still good.
I need help.
Old Aug 26, 2009 | 04:57 PM
misha's Avatar
Default Re: Help DA cluster in USDM 91 Si
you absolutley sure that all wire are in correct? i had that cluster in my dx everything worked
Old Aug 26, 2009 | 05:02 PM
im pretty sure.i used the pinout i used was from here http://trever.mcdermott.googlepages.com/pdfdocuments
which one did you use?
Old Aug 26, 2009 | 05:03 PM
And here is the DA pinout I used
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/da-cluster-1755357/
Old Aug 26, 2009 | 05:11 PM
misha's Avatar
i cant remember they are in my thread i think you can look it up not to far from start? sorry im lazy lol
Old Aug 26, 2009 | 05:24 PM
also a blue connector that has 4 wires.what do i do with that?
Old Aug 26, 2009 | 05:44 PM
bumpety-bump
Old Aug 26, 2009 | 06:07 PM
lol nvm the hazards weren't hooked up.
so someone lock this plz
Old Aug 28, 2009 | 12:38 AM
jenifertom90's Avatar
check out the lights.it is very important as you have to use it every now and then....have you checked the light being used in it....is it halogen,OEM or HID.....check it out and get it repaired or replaced whichever you want to.
patrickstar
19
Mar 1, 2009 09:13 AM
peter96ek
Feb 15, 2008 01:52 AM
Wuffer
Jul 30, 2007 05:14 PM
chadmasterc
Jun 4, 2005 09:42 PM
element_1one
Jun 3, 2003 09:08 AM
