Da cluster
Old 09-18-2006, 01:09 AM
keepitngga1's Avatar
Default Da cluster
I have a cluster from a obdo 91 integra and i want to put it into my crx.. yes i tried searching but only found jdm ukdm clusters.. any help on how to plug it up.
Old 09-18-2006, 01:37 AM
661rex89si's Avatar
Default Re: Da cluster (keepitngga1)
im wondering myself also any write up on how to install and wire up
Old 09-18-2006, 04:25 AM
IndySporty's Avatar
Default Re: Da cluster (661rex89si)
I have one of those "honda swap" cd's and the author has a lot of cluster write-ups, but states that the only way to safely install a DA cluster of any kind is with a DA dash swap because it can't be made to fit in our housings. I wouldn't know I have a 00 Si cluster.....
Old 09-18-2006, 06:15 AM
93cavRS's Avatar
Default Re: Da cluster (IndySporty)
what about a dc2 cluster? are they plug and play or need to be wired up, i see lots of them in ef hatch's and rex's, if ya do need to rewire it how hard is it?
sorry for the thread jack, jus didnt wanna waste more space lol
Old 09-18-2006, 06:23 AM
gibsanez's Avatar
Default Re: Da cluster (93cavRS)
I have the pinout for the LS cluster at home, i'm at school right now, if someone else doesn't post it, i will within the next couple hours.
It's not hard to rewire, just have some extra wire becuase you'll need to extend 2 wires for the DA. The da is easier too because it's a cable VSS.
What do you mean can't be made to fit our housings?...And yes i know i don't drive an acura
Edit - here ya go
90-93 integra ls pinout
PIN Wire Color Wire Function
A1 Yellow/Red Seat Belt Reminder Light
A2 Green/Red Parking Brake Switch Light
A3 Green/Black Hatch Open Indicator Light
A4 Green/Red Low Fuel Indicator Light
A5 Yellow/White Fuel Gauge
A6 Yellow/Red ECM, Trans Control, Moduel TCM, Cruise Unit, VSS
A7 Red Gauge Lights, Dash Light Dim
A8 Empty
A9 Red/Black Gauge Lights
A10 Green/Yellow Right Turn Signal Indicator
B1 Green/Blue Left Turn Signal Indicator
B2 Red/Blue High Beam Indicator
B3 Blue/Red ABS Indicator Light
B4 Blue Tachometer
B5 Green/Red Door Open Indicator Light
B6 Yellow/Green Engine Coolant Temp Gauge
B7 Black Ground
B8 Yellow Ignition Power
B9 Green/Orange Malfunction Indicator (Ck Eng.) Light
B10 Black/Yellow Charging Sysem
B11 White/Blue Charging System (Battery) Light
B12 Yellow/Red Low Engine Oil Pressure Light
Modified by gibsanez at 12:47 PM 9/18/2006
Old 09-18-2006, 07:48 AM
philkehn's Avatar
Default Re: Da cluster (gibsanez)
Edit: you got there before me i guess, or i just wasnt reading
Old 09-18-2006, 08:11 AM
gibsanez's Avatar
Default Re: Da cluster (philkehn)
Looks like i beat you by just a minute
Old 09-18-2006, 05:04 PM
alright sounds good..thnks for the help
Old 12-05-2015, 05:19 PM
Kevin Marti nez's Avatar
so i want to put this cluster on my ED6 but dont know how to put it properly, can u help me man, please
ricerollz
09-26-2010 09:52 PM
geezyctr
02-13-2010 08:26 PM
ef-b16sedan
07-07-2006 01:21 PM
chbtek6
01-11-2004 10:24 AM
wickedEFguy
12-11-2002 09:58 PM
Quick Reply: Da cluster
