how do I clean out a/c drain line?
Old Aug 26, 2009 | 03:26 PM
mattbatson's Avatar
Default how do I clean out a/c drain line?
I have cold water dripping onto the passenger front floorboard when the a/c is running.
I found the condensate line, where it runs down the firewall outside... and I'm assuming it is clogged and this is what is causing the problem.
Do I just blow compressed air up it? Or will this just blow the gunk further up into the system?
Try and hook a wet vac up to the end of the line?
thx.
Old Aug 26, 2009 | 03:33 PM
gearhead16's Avatar
Default Re: how do I clean out a/c drain line?
air compressor and a air blower just blow it up through there and stand back if you have enough pressure it will rush out everywhere this is how we do it at honda
Old Jun 23, 2011 | 12:49 PM
Rat_Bear's Avatar
So did you try this or what? Cuz I'm having the same problem but its just dripping a little so far inside the car.
trooper0641
Dec 2, 2010 05:55 PM
kuks24
Honda Civic (2001 - 2005)
Jul 13, 2008 01:13 PM
98ludesh17
Apr 20, 2007 02:40 PM
Zbad1
21
Dec 16, 2006 07:32 AM
newhondaowner29
Jun 8, 2005 08:44 AM
