B16A swap wont start, no cel light and no oil light
Old Aug 26, 2009 | 08:31 AM
kleeg9's Avatar
Default B16A swap wont start, no cel light and no oil light
i need some help with fixing a problem with my car. Its an EG8 sedan. was 1.6 vtec (d series). Was running 100%. Took the engine out and dropped in a mint B16A engine out of a 94 EG6. And it wont run
So I'll explain this as best i can..
When I try to start the car it is getting fuel and is sparking, it cranks over but it wont start. I've tried a different ecu but still the same. With the ignition on I am not getting a CEL light or a OIL light..
I had the dash out and i had the engine bay stripped to paint the bulk head. I put everything back in myself and checked everything 4 times at this stage.
EVERY SINGLE EARTH IS CONNECTED AND EVERY PLUG IS IN. Not one single wire is stripped, cut or pinched. I had dash back out tonight and checked every single wire with a multi meter...
The sir P30 ecu is what i'm using
That is all I can say.. I had a mechanic and an auto electrician look at it this evening and they couldn't see anything wrong.
Thanks very much for taking the time to read this and if anyone can help it would be greatly appreciated. If anyone needs to no anymore please do
Old Aug 26, 2009 | 09:10 AM
Former User's Avatar
Default Re: B16A swap wont start, no cel light and no oil light
No CEL or oil light: Is fuse 15 under the dash blown?
Have you double checked the mechanical timing?
Have you compression tested the cylinders?
Old Aug 26, 2009 | 02:34 PM
kleeg9's Avatar
there is no fuses under the dash that are gone and none in the engine bay.. I've a mechanic callin down tomorro eveninso i'll get him to check the mechanical timing and the compression.. It sounds like it wants to start but it just wont
Old Aug 26, 2009 | 02:51 PM
Check whether fuse 15 is blown, not missing.
rayzian
13
Feb 22, 2018 04:54 PM
kleeg9
Engine Management and Tuning
Aug 26, 2009 08:21 AM
fishinfool88
Dec 8, 2008 07:48 AM
nemeii
23
Aug 10, 2008 03:10 PM
superturboprelude
Oct 29, 2003 11:42 AM
