apexi vtec controller?
Old Aug 25, 2009 | 06:20 PM
jkalex05's Avatar
Default apexi vtec controller?
I currently have a b16a2 swap the previous owner put on and he used a JDM P73 ECU since my car is a 96 EX which is OBD2A.
Now everything is running fine but my vtec engages at 6k instead of 5500rpms. I was thinking of buying a vtec controller to lower my vtec atleast down to 5500 and see how it does maybe at 5200rpm.
What do you all think about the Apexi VAFC controller? My friend has one he is gonna give me, it isnt he newest one. Its the black one.
Old Aug 25, 2009 | 06:52 PM
vvboy's Avatar
Default Re: apexi vtec controller?
i think it your speedo cluster it a little off by 500 rpm.i think chip it with good tuneis better
Old Aug 25, 2009 | 07:08 PM
jasoncrashtech's Avatar
you should get the correct ecu. timing, fuel aren't going to be right with what your doing
afc isn't a tool i recommend trusting. it tricks the map sensor and so on. it's a hack.
you'd have best luck using a stock ecu (for your b16), but if you only want it for that reason remember this, when you use the afc and lower vtec to like say 5500 or 5400 the power drops off right before or during that setting. everything needs to be adjusted for a smooth transition but even then it's a hack tool. don't adjust it too low either the oil pump needs rpms to generate oil pressure that is very important to the head of your motor.
Old Aug 25, 2009 | 07:48 PM
forcefedferio's Avatar
what jason said, times a million.
Atleast you were intending on using it to get it closer to stock, but i also believe your cluster is a bit off, which is not uncommon at all. I've seen them off by over 3000rpm. (<~~not a typo.)
If he is willing to give it to you, take it. a few years ago i got one for free in a weird deal and i wired it up (used to use it to lower VTEC engagement point until i learned through research and others on h-t.) After i learned that this was actually WORSE, i rewired it so it didn't not mess with any tuning but was basically a cool looking digital gauge.
Old Aug 25, 2009 | 10:51 PM
jkalex05's Avatar
I think im just gonna buy a chipped p28 and a obd2a > obd1 harness.
Old Aug 25, 2009 | 11:41 PM
Corksil's Avatar
Get the right ECU for your swap, I dunno which one you need..
OEM ftw!!11!!!!!
As someone else said, AEM vtec controller is a hack, it's not the way it should be. It's a little fcukup, otherwise known as a loophole, so it's not really going to fix your problem. Like a bandaid on a severed limb, it's not the right solution for the size of your problem...
Old Aug 26, 2009 | 05:07 AM
crxrider's Avatar
been using the vafc with hondata for years, the vafc is good for dropping vtec and having a gauge to watch engine vitals, however i never recomend using a vafc for tuning, always go with a reputable company for a tune.
i recomend converting to obd1 and getting a good tune, if your engine is anything like the last z6 i did it ran so rich off the stock ecu that using a vafc and dropping vtec engagement wont hurt the motor.
however never, ever try to tune a vafc yourself, and never use it as a substitute for a good tune.
Old Nov 18, 2009 | 11:43 PM
dj theoretic's Avatar
VERRYYYY TRUE..... I WOULD SUGGEST HONDATA OVER ANYTHING!!! IF YOU DO SO,,,,,,,,,,HONDATA S100, P28 TUNED (INCLUDING DYNO WOULD BE GOOD)
http://www.hondata.com/s100.html
blacktibby07
Jun 8, 2011 07:11 AM
triggerman77
Feb 13, 2010 12:07 PM
honda_boy23
Apr 13, 2008 05:59 PM
sasinorm01
Aug 1, 2004 08:50 PM
Superdragr45
Honda S2000
Sep 14, 2003 04:40 PM
