avid motor mount trouble
Old Aug 25, 2009 | 02:15 PM
poorhonda's Avatar
Default avid motor mount trouble
i have a 91 civic hatch that im doing a ls swap in and i just got the avid motor mounts. now the driver side motor mount dose not match up to the ls motor and i was going to swap the mount with the d series motor but dose not match up to the block any idea's???? I was thinking taking a mount off a obd1 or obd2 d series block and hopeing that will match up has any one had this prob befor?????
Old Aug 25, 2009 | 02:21 PM
johnnyonth3spot's Avatar
Default Re: avid motor mount trouble
any pictures or additional informatiion like how it doesnt match up?
Gunmetal_B20_Hatch's Avatar
are you mixing up the 2 and 3 bolt style mounts?
Old Aug 25, 2009 | 02:33 PM
poorhonda's Avatar
http://i117.photobucket.com/albums/o...0825091824.jpg
Old Aug 25, 2009 | 02:34 PM
poorhonda's Avatar
http://i117.photobucket.com/albums/o...825091824a.jpg
Old Aug 25, 2009 | 02:35 PM
poorhonda's Avatar
the avid mount will fit on the stock d motor but wont fit on the b motor cant i swap the motor mount it self maybe from a obd1 or 2 motor and the mount should fit
Old Aug 25, 2009 | 02:37 PM
poorhonda's Avatar
because the mount off the obdo motor wont bolt up 2 the ls
Old Aug 25, 2009 | 02:40 PM
try a B18A engine-side mount? I think they are 2-bolt.
Old Aug 25, 2009 | 02:50 PM
poorhonda's Avatar
thats what the mount in the pic is
Old Aug 25, 2009 | 03:47 PM
OK, then I would swap your current Avid mount for a 3-bolt style one and call it a day.
3-bolt is a better design anyway.
Old Aug 25, 2009 | 04:19 PM
EJ1_Sleeper's Avatar
the bracket you have pictured is a 94+ DC B18B1 driver side bracket, the bracket you need is a 90-93 DA B18A1.
fatfurious2
Mar 6, 2009 02:09 PM
thaipham806
Nov 24, 2006 03:30 PM
