gsr clutch slipping but its brand new
ok eg with a 97 gsr b16 trans, now to the problem... when i did the swap i put in a new Competition Clutch stage 2 i have the box to prove it lol i replaced the throwout bearing that came with the kit and after everything was dropped in when i try to take off it slips like crazy, it makes a loud pssssshhhhhhh noise in every gear when its under a load or when i push in the clutch. it shifts fine no grinds goes in first when im stopped all the good stuff any ideas?
pull the clutch out and clean it with break cleaner sounds to me like you got something on it.
not putting grease on the throwout bearing would casue it to sqeek.
did you reserface the fly wheel? or replace?
Also, you should ALWAYS at least resurface the flywheel when replacing the clutch. This may be a major cause of your problem right there.
redman223
Mar 1, 2024 01:55 PM
vtecaccordf22b1
Dec 2, 2007 04:18 PM
