Obd 1 cel question
Old Aug 24, 2009 | 04:58 AM
egreenmachine's Avatar
Default Obd 1 cel question
Hey guys got my swap running however my car is throwing codes 3,10,14. If anyone could help I believe these are just the wrong plugs connected. If anyone could help me with location and wiring coloration for these sensor it would be greatly apprectiated.
3: map sensor
10: intake air sensor
14: EVAC idle air control
Old Aug 24, 2009 | 07:46 AM
Funanin's Avatar
Default Re: Obd 1 cel question
what motor/ecu/vehicle/harness is it?
Old Aug 24, 2009 | 09:33 AM
Ls/v with a 2000 gsr head and b18a bottom end. B16 wiring harness and obd1 p72
Old Aug 24, 2009 | 10:10 AM
Former User's Avatar
Does the engine run poorly?
If you reset the ECU and run the engine, do all three codes return?
Old Aug 24, 2009 | 12:30 PM
Yes the engine runs poorly, it will not rev past 1500 so i believe i need to fix these wiring issues to have it run correctly. Also I have to baby the gas to keep it runny, once it start after a few blips on the accelerator it evens out to about 900 rpms.
4g4dcruisin
Feb 14, 2010 07:23 AM
dividedas1
May 28, 2009 11:22 AM
swoyEKr.
Dec 28, 2006 11:42 PM
Coltmorris
Oct 22, 2006 07:11 AM
MarkAngelo
May 22, 2004 10:32 PM
