Civic Engine Help! Swap...
I just bought a 1998 Honda Civic EX with a d16Y8 engine and 5spd transmission. The engine is shot and has a bad rod knock. I just want to swap a motor in here that will work. What engine codes can I use? Also what years? Thanks in advance!!
anything and everything!!!
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/engine-swap-info-faqs-how-ck-engine-lights-878010/
that might help???
that might help???
Rod knock... Why are these motors so susceptible to this?
Ive had 2 motors with rod knock.
Are you into performance?? If so swap in a B16 or LS, or VTEC B18. If not swap in another Y8 and keep an eye on your oil.
But,,,,I am in the same boat in that I have a Non vtec and bought a VTEC Motor w/ECU I know I have to add a few wires to the ecu and tie in the Vtec solenoid,,,
But will it hurt anything run without the Vtec solenoid being hooked up???
