95 rear disc conversion question.
Old Aug 19, 2009 | 12:01 PM
italian_virus's Avatar
Icon2 95 rear disc conversion question.
Whats up guys.. im doing a rear disc conversion on my 95 civic si coupe
so far
i have my
master cylinder
prop valve 40/40
rear disc's from a GSR
Dot 5 brake fluid
& im in the process of get some SS lines.
the question i have for you guys is that on the rear discs the ebrake cable are snapped/cut..
so i have to purchase another set of cables... i was wondering if anyone knows which cables i need i believe its either the
6th gen SIR ebrake cables
or the GSR ebrake cables..
i know one is shorter than the other.. i believe its the GSR.. im not too sure thats why i made this post.. if anyone can help me out i would really appreciate it
thanks in advance
Old Aug 19, 2009 | 12:17 PM
95jeremie's Avatar
Default Re: 95 rear disc conversion question.
well as far a the e-brake cable i don't know
but for the love of god don't use dot 5
dot 5 is silicone based and will **** up your abs
there is a new fluid out dot 5.1 it's the same as dot 5 but not silicone based
the valves in abs move fast as hell allowing pressure and bleading off pressure
that rapid movement causes bubbles to accure in sillicone based fluids
your good with dot 4 but if ya just want the best go dot 5.1
Old Aug 19, 2009 | 12:22 PM
Skip01's Avatar
Doubt he has abs if he's adding disc brakes just now.
Old Aug 19, 2009 | 12:33 PM
95jeremie's Avatar
true...
regardless
the silicone will eat at the factory brake lines (from what i was told)
so why risk it?
just use the right ****
Old Aug 19, 2009 | 02:25 PM
my bad guys
i meant 5.1
i know about the silicone base in the brake fluid
but thanks for keeping a look out hahah
and yah i do not have abs..
anyone ?
Old Aug 19, 2009 | 02:34 PM
raidacaipo's Avatar
it doesnt matter which e brake cable you use... they all work the same. I have 95 gsr rear disc brakes on my 97 honda civic. The e brake cables work whether its a gsr or not. all 94-01 integras rear disc brakes works including cables and same goes for 92-95 civic Si and all 99-00 civic si
and whats wrong with dot 3?
Old Aug 20, 2009 | 07:29 AM
really? i thought it did make a difference...... so im looking for the integras ebrake lines..
i actually thought there were different sizes ;s
Old Aug 20, 2009 | 09:29 AM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Good luck getting all those bolts off if you're in T-dot. Rusted solid. I recommend PB Blaster from Crappy Tire, but even that won't cut it I'm thinking, based on my experience at the wrecker's.
For my brake swap I'm going to prep with PB, then mark which bolts I want loosened and bring it in to a shop and have them loosen with air tools and apply some anti-seize.
Old Aug 20, 2009 | 09:41 AM
fungus mungus's Avatar
Yeah, I recall there being a lot of unhappiness experienced by a HT member who recently sheared off a bolt when trying to remove his old knuckles...better safe than sorry.
fm
Old Aug 20, 2009 | 02:34 PM
reyracerx's Avatar
so far
i have my
master cylinder
prop valve 40/40
Dot 5 brake fluid
thanks in advance
are you sure its a 95 si/ex-s coupe and not just an ex?? becuase si/ex-s coupes should already come with rear disc and ABS. anyways, to answer your e-brake cable question you can use any from 90 through 00 integra. they fit perfect and you can find plenty of 90-93 integras in the junkyards.
Old Aug 20, 2009 | 04:06 PM
Allurian's Avatar
1. any ebrake cables from any integra/ civic with rear disks.
2. sell prop valve, not needed for swap and provides ZERO benefit. This topic has been beaten to death in another forum. 95 Civic Si's use 3030 with their rear disks
3. Dot 3 brake fluid is all you need
Old Aug 20, 2009 | 04:53 PM
jcdimvic's Avatar
any disc cables from integras will work i got 91 cables on my 95 coupe. most wreking yards are dirt cheap. I think i paid 7 bucks for both of em.
Old Aug 20, 2009 | 05:10 PM
raidacaipo's Avatar
x2!!
I cant stress this enough either.. I have integra rear disc brakes on my 97 civic hatchback and I didnt even need to change the prop valve either.. its been argued that 40/40 prop comes on all 96-00 civic hatches which to me seems true because I havent touched my prop valves and they brake just as good as any integra but even better with performance pads and rotors.
Old Aug 20, 2009 | 05:50 PM
deschlong's Avatar
Loved
Community Favorite
He's from Canada. It's a 95 Si Coupe with rear drums.
But, you make a good point. If you want to find the exact part number that exactly matches the cables you need on a Coupe with rear disc -- look up the part number for the US EX Coupe w/ ABS:
WIRE A, R. PARKING BRAKE - 47510-SR4-933
WIRE A, L. PARKING BRAKE - 47610-SR4-934
These parts are found on the following vehicles. (Remember, US 4dr EX = CDM 4dr EX-V):
CIVIC 92 93 4DR EX ABS
CIVIC 94 4DR EX ABS 4DR LX ABS
CIVIC 95 4DR EX ABS 4DR LX ABS
CIVIC 94 2DR EX ABS
CIVIC 95 2DR EX ABS
INTEGRA 94 4DR LS 4DR RS
INTEGRA 94 4DR GS-R
INTEGRA 95 96 4DR LS 4DR RS 4DR SPECIAL
INTEGRA 95 96 97 98 4DR LEATHER GS-R 4DR GS-R
INTEGRA 97 98 99 4DR LS 4DR LEATHER GS
INTEGRA 99 4DR LEATHER GS-R
Old Aug 31, 2009 | 05:42 PM
thanks guys for the input i appreciate it
well i already bought
dot 5.1
and a 40/40 prop valve
and SS lines..
lol soo all i need left is the ebrake cables
which now i know the answer
thx again
Old Oct 5, 2009 | 11:09 AM
CIVIC 94 2DR EX ABS
CIVIC 95 2DR EX ABS
INTEGRA 94 4DR GS-R
just one last quick question for you guys.. i found the part.. im just curious..
would it be better if i bought this new or used??
nicolaselias
Jul 18, 2011 07:55 PM
x_doug-x
13
Jan 22, 2010 05:44 PM
wesley_925
Jul 3, 2008 10:16 PM
Civic94girl
Suspension & Brakes
May 13, 2005 02:01 PM
Mr. Choi
25
Oct 2, 2004 09:03 AM
