throttle actuated scoop
Old Aug 18, 2009 | 11:18 AM
acura_el2000's Avatar
Default throttle actuated scoop
I was just brainstorming ways to improve the airflow my intake can receive and I have always kinda wanted to make a hood scoop that pops out of the hood when throttle is applied... a la 1970 Chevelle SS
not sure if I want to go with the cowl, or have a forward facing scoop.
Old Aug 18, 2009 | 02:43 PM
got wide's Avatar
Default Re: throttle actuated scoop
dont know about attaching it to the throttle, but iv'e been thinking about pluming a cold air intake into a ram air scoop in the front bumper but using a exhaust cut out (electric or manual) to divert it when its raining out. that way it doesnt HAVE to open every time you hit the gas
Old Aug 18, 2009 | 03:23 PM
SinCitizen's Avatar
New User
scoops like the one on the chevelle are vacume operated
Old Aug 18, 2009 | 04:28 PM
would a civic have enough vacuum pressure to actuate one? I could always buy a replica part for it then rob the mechanism
Old Aug 18, 2009 | 04:50 PM
mikesrex's Avatar
you could also actuate it with boost if you have a turbo car
Old Aug 18, 2009 | 05:32 PM
got wide's Avatar
whats vacuum pressure?? j/k it would depend on how big the diaphragm in the actuator is. think about your brake booster that adds a **** ton of pressure to the master cylinder piston.
oh and you would probably want vac to hold it closed so when your on the gas the vac releases and opens the scoop.
you could probably buy a used waste gate actuator or any vacuum actuator and adapt it cheaper than buying a replica for the chevelle
Old Aug 18, 2009 | 05:36 PM
i had to read that over twice to get what I said lol.
I agree with what your saying it makes sense, what could I tap into that wont have ill effects?
The car is supercharged btw.
Old Aug 18, 2009 | 05:52 PM
got wide's Avatar
what kind of charger/do you still have decent vac at idle? as long as you have vac at idle even if its small you could use a vac resevoir with a one way valve to hold the vac untill needed.
also look into all the 70's-90's cars with pop up headlights, almost all of them are vacuum actuated.
just tap into anything coming off the IM or use a vac block if you want it to look a little cleaner
Old Aug 18, 2009 | 09:05 PM
Jaker's Avatar
1981 Camaro Z28 had the same thing. There was a reverse buldge on the hood, and a flap that opened at the base of the windshield when the pedal was stomped. My brother in law had one, and I was always trying to talk him into gassing it to open the flap. It made the coolest induction noise.
Old Aug 18, 2009 | 10:48 PM
Stachi's Avatar
You could also use a pneumatic cylinder. Modern cylinders don't care much if they are operated by pressure or vacuum.
Marc
Old Aug 26, 2009 | 07:47 AM
perseverance's Avatar
you can make it electronic, basically have it on a wot switch and then have it open using a solenoid. and on that switch, u can put a toggle so that when it's raining it doesn't have to open. just a suggestion
Old Aug 26, 2009 | 09:00 AM
Nataku's Avatar
if you are savvy with electrical engineering... Using the reading from the TPS to control a servo.
notned22
Jul 13, 2016 04:14 PM
casserlyshane
Oct 6, 2014 04:11 PM
chiheat
Honda S2000
15
Jun 17, 2005 08:22 AM
djtech
Feb 27, 2003 08:55 AM
hondasir1988
Jul 17, 2001 09:03 PM
