Honda S2000 Honda S2000
Throttle bodies.
Old Jun 15, 2005 | 03:44 PM
chiheat's Avatar
Default Throttle bodies.
Can someone please explain what a throttle body does.. Also, maybe help me pick one out. My buddy was saying something about them, so I would like to know what it does Thx.
Old Jun 15, 2005 | 03:55 PM
WowOzYouRock's Avatar
Default Re: Throttle bodies. (chiheat)
LMAO ... hmmm throttle body is a door for air flow that goes to the intake ... the bigger the bore the more air flow ... i was going to be an ******* but i decided to be nice *cheese*
stock throttle body work fine kid ...
Old Jun 15, 2005 | 03:56 PM
Mr. Bagel's Avatar
it let's air in. when you hit the gas pedal the butterfly valve opens up. do a search, or better yet, ask a friend to remove the intake tube off of your car so you can see and then put it back on.
if you don't know what it is/does, then at this point, you don't really need one.
Nishant's Avatar
Default Re: Throttle bodies. (Y2K_S2K)
better throttle bodies mainly help with throttle response. only seen very very small/no gains on the dyno
Old Jun 15, 2005 | 03:59 PM
Default Re: Throttle bodies. (Mr. Bagel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Bagel &raquo;</TD></TR><TR><TD CLASS="quote">it let's air in. when you hit the gas pedal the butterfly valve opens up. do a search, or better yet, ask a friend to remove the intake tube off of your car so you can see and then put it back on.
if you don't know what it is/does, then at this point, you don't really need one.</TD></TR></TABLE>
can you break it down for me plssss LMAO ... what is gas pedal and butterfly valve?
Old Jun 15, 2005 | 04:29 PM
Nishant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Y2K_S2K &raquo;</TD></TR><TR><TD CLASS="quote">
can you break it down for me plssss LMAO ... what is gas pedal and butterfly valve? </TD></TR></TABLE>
noobs
Old Jun 15, 2005 | 06:15 PM
97ShLude's Avatar
Default Re: Throttle bodies. (Nishant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nishant &raquo;</TD></TR><TR><TD CLASS="quote">better throttle bodies mainly help with throttle response. only seen very very small/no gains on the dyno</TD></TR></TABLE>
A bigger bore throttle body will let more air in, which equals more power (well as long as there is enough fuel)
Old Jun 16, 2005 | 04:46 PM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
Default Re: Throttle bodies. (97ShLude)
I would expect this question from my g/f, but not from someone who has an S2K in their signature.
Ask jeeves.
Old Jun 16, 2005 | 06:53 PM
Nishant's Avatar
Default Re: Throttle bodies. (NAallTheWAY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAallTheWAY &raquo;</TD></TR><TR><TD CLASS="quote">I would expect this question from my g/f, but not from someone who has an S2K in their signature.
Ask jeeves. </TD></TR></TABLE>
help him out, no need to flame
Old Jun 16, 2005 | 08:04 PM
EFSS153
Definition: A housing containing a valve to regulate the airflow through the intake manifold. The throttle-body is usually located between the air cleaner and the intake plenum.
Sorry for the flamage.
Old Jun 16, 2005 | 08:58 PM
Voodoo_s2k's Avatar
A bigger bore throttle body will not do anything for you unless your engine requires/needs more airflow. Putting a larger throttle body on without making other improvements will just result in slower throttle response and slower pickup unless the stock one is restrictive which isn't the case with the S2000.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97ShLude &raquo;</TD></TR><TR><TD CLASS="quote">
A bigger bore throttle body will let more air in, which equals more power (well as long as there is enough fuel)</TD></TR></TABLE>
Old Jun 16, 2005 | 09:02 PM
Voodoo_s2k's Avatar
Default Re: Throttle bodies. (Voodoo_s2k)
Old Jun 16, 2005 | 10:22 PM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
It's the ***** of an engine
Old Jun 17, 2005 | 07:40 AM
chiheat's Avatar
thx... i expected flames.... doesnt bother me much.
Old Jun 17, 2005 | 08:09 AM
Mr.E.G.'s Avatar
Default Re: (chiheat)
dude, come on.
you really should not be trying to modify a car without some basic knowledge.
this is like a gun enthusiast asking what bullets are.
really man, just search a little, or go to the library. that is a very basic question.
in about six months you are going to look back and be embarrassed that you asked this question.
try howstuffworks.com
and read all of thier stuff on engines and so forth.
it doesnt get any simpler than that
Old Jun 17, 2005 | 08:22 AM
Nishant's Avatar
Default Re: (Mr.E.G.)
i thought a bigger throttle body wasn't needed unless some head work was done
chunkybs
Oct 20, 2007 11:56 AM
Nicks95GSR
Aug 9, 2007 09:56 PM
97V6ACCORD
Jun 7, 2002 09:15 AM
materina
Dec 19, 2001 02:47 PM
hondasir1988
Jul 17, 2001 09:03 PM
Top
Follow Us
