Brights Stuck On
Just wondering if anyone knows what might cause this problem, I am looking at an 06 FG2, the problem with it is that the left bright bulb does not light up, and the brights will not turn off at all.. as soon as the headlights are on the brights are on and will not turn off, but the left bulb is either burnt out or just not functioning, any ideas?
i would assume brights are high-beams...have you not heard anyone call them that before? that's a pretty common word for them..
OP, are you out of warranty? Have you altered the lights at all since you got the car?
figured it out, the multiplex actually got a little wet and there was no power to the driver's side high beam fuse, went ahead and replaced the multiplex (fuse box) and everything works just dandy
Kohen
Oct 14, 2011 08:44 AM
