radiator problem
Old Aug 25, 2002 | 07:11 PM
clean's Avatar
New User
Default radiator problem
i wentr for an hour drive to go to a car show in NH and on my way back i wanted to check if everything was all goood w/ my turbo and what not and found that anitfreeze was leaking out of the overflow tank. it was packed full and spillling out a little at a time. so i thought that the thermastat was broken, so i decided to crank the heat and open the windows so that the engine wouldnt overheat. then i went 3 more hours to camp and i just got home. it's stil full and it dint over heat. the temp gauge on the cluster dint move, maybe cause it's broken, but the fan on the rediator works. does anyone really know what could have happened to my car and is my thermastat broke, cause thats the only thing i can think of?
Old Aug 25, 2002 | 07:52 PM
bryant's Avatar
Default Re: radiator problem (clean)
if its not overheating, i dont think your thermostat is broken. Just maybe you put to much fluid in and that is what the overflow tank it for. Dump out what you need to and drive it around close to home and see if over heats or gets close.
Old Aug 25, 2002 | 09:16 PM
Volcom's Avatar
Default Re: radiator problem (CR-X)
Yea, if its not overheating or not warming up at all (that's what my was doing before I replaced it), I don't think it the theromstat.
Old Aug 26, 2002 | 10:04 AM
clean's Avatar
New User
Default Re: radiator problem (Volcom)
i dint fill it up guys, i have never fillled it up and i couldnt tel if it was overheating cause i had the heat cranked. the temp gauge could be broke, does it work if the thermasat is broke?
Old Aug 28, 2002 | 06:46 AM
clean's Avatar
New User
? im replacing it anyway cause its cheap and i do think it is closed
Germizzooo
Jan 16, 2011 02:10 PM
microfunk5
Honda Civic (2001 - 2005)
Sep 21, 2010 07:45 AM
JDMfan77
13
Jul 20, 2010 06:30 AM
DaveSi677
Jul 5, 2006 10:35 AM
