k20a motor is surging *help* please
Old Aug 17, 2009 | 09:34 AM
ekmonsterN/A's Avatar
Default k20a motor is surging *help* please
my motor is surging ... the engine light is not on... when i unplug the idle air control valve the motor revs and stays at 2000 rpm at idle ... do you guys think i need a new idle air control valve? ... ps i took the valve apart and cleaned it already and the valve does move and spring back .. thanks guys!
Old Aug 17, 2009 | 04:30 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Default Re: k20a motor is surging *help* please
try oiling it. I just had to clean mine cause my car kept stalling out and I read to oil it.
But also check for vacuum leaks. Water bottle and soap
Old Aug 17, 2009 | 05:16 PM
Rollo Lawson's Avatar
my k20a2 is doing the same thing, but only at wot in 4,5 & 6th gear. i've narrowed it down to either the tps or map sensor. but, i did get a a cel light about a month ago. tps voltage reading too high
Old Aug 18, 2009 | 03:52 AM
hawaiiancb74's Avatar
take off intake, start car, cover hole inside throttle body for the iacv with your finger and see if it stops, if it does then you found the problem, cleaning them sometimes does not fix them. if it dosent stop the problem it could be a number of other things like air bubbles in your coolant, map or tps, dirty vtc, or crank sensor, loose cam sensors..
68cam
19
Dec 15, 2008 10:52 AM
Al-sonic
Jan 14, 2007 03:56 PM
Norrod
Nov 18, 2005 08:16 AM
paul93sir
Feb 5, 2004 11:26 AM
Nerologic
Oct 4, 2003 11:03 PM
