idling problem
Old 01-14-2007, 01:12 PM
Al-sonic's Avatar
Default idling problem
could it be the thermostat or the map sensor. it idles when the car is warm up and sometimes when i am driving the car. what could it be. help please
Old 01-14-2007, 01:13 PM
A.E Motoring's Avatar
Default Re: idling problem (Al-sonic)
well wat does it do?
Old 01-14-2007, 02:28 PM
Al-sonic's Avatar
Default Re: idling problem (Dual Cam Racing)
it just idle from 2000 rpm to 1500 rpm up and down it only do it if the engine is warm
Old 01-14-2007, 02:32 PM
1. check all vacc lines
2. clean IACV
3. check tps voltage
4. check for any kind of air/vacc leaks, get some carb cleaner spray around the intake manifold, if it bubbles, theres your leak.
did u change anything? or mess with anything at all? any codes?
Old 01-14-2007, 03:56 PM
shailoche's Avatar
definitely sounds like you need to clean or replace your idle air control valve (IACV.) That is what is primarily responsible for smooth idle on the stock honda motor.
omar pelayo
12-03-2018 10:50 PM
bads2k
02-02-2010 10:07 AM
vdawg559
06-11-2008 04:31 AM
verbal_assasin
03-01-2006 01:09 AM
Successor
04-30-2003 04:04 PM
Quick Reply: idling problem
