TILTON CLUTCH ISSUE !! HELP
Old Aug 15, 2009 | 07:50 PM
94turbosi's Avatar
Default TILTON CLUTCH ISSUE !! HELP
Hey, im looking for some help with my tilton twin disc , i recently installed a tilton twin disc ceramic clutch on a b series transmission with tilton master and hydraulic throwout bearing and also flow control valve , car shifts smooth normal driving conditions, ive tried bleeding several times, adjusting pedal stop from its lowest point to its highest point and at higher revs gears do not go in . has anyone had any sucess using this type of set up with a stock synchro transmissions, or is it only meant to work with dog engagement? thank u .
Marco
Old Aug 16, 2009 | 05:09 PM
94turbosi's Avatar
Default Re: TILTON CLUTCH ISSUE !! HELP
Marco
Does anyone have any helpfull info ??
Old Aug 16, 2009 | 06:06 PM
Adriano's Avatar
Yeah, put back the stock fork and bearing!
Adriano
Old Aug 16, 2009 | 06:27 PM
94turbosi's Avatar
Adriano
Trying to avoid that route ... Has to work!! Several people have had success!
Old Aug 17, 2009 | 03:43 AM
turbotypeR@SPEC's Avatar
25 Year Member
Where is the pedal when the clutch engages? Is it high or low?
Old Aug 17, 2009 | 04:01 AM
Adi Radoncic's Avatar
On Fire!
What gear are you adjusting the engagement in? I had the same issue for a while, wasn't able to shift at high rpm so I tried adjusting while the car was in 3rd or 4th gear and it worked for me..
Old Aug 17, 2009 | 04:36 AM
94turbosi's Avatar
Ive tried either way high or low i tried several different pedal heights , from its stock point to its lowest setting , at it lowest travel point if i had the pedal all the way down and would hit the too step car would move foward.
Old Aug 17, 2009 | 04:37 AM
94turbosi's Avatar
I was adjusting pedal travel with 1 gear . i will try to adjust it at 3-4 gear like u said ill give it a shot thanks
Old Aug 17, 2009 | 01:51 PM
HPgonewild's Avatar
Thank u (turbo type r) and (adi radoncic) out of 220 views i have too fellow honda tech racers that are willing to help out . i thought this web site was to help each other out with imput . Do i have to be a well known member to get some real tech info here .
chill out. Maybe the other 218 viewers are just wanting to read and learn from the others that made gave the input. Or maybe some of those 218 viewers have the same problem and just waiting for to see some answers like you.
Just because there's views doesnt mean everyone has to chime in and say they dont know the answer.
Old Aug 17, 2009 | 02:07 PM
El Tigre Racing's Avatar
Make sure you installed the hydrolic bearing the right way. I seen a few people instal them backwards. Did you use the correct fluid?
El Tigre
Old Aug 17, 2009 | 03:21 PM
25 Year Member
How are you shifting when it is having the trouble? Are you shifting full throttle, or lifting on each shift? Does it have trouble shifting in all gears?
Old Aug 17, 2009 | 03:33 PM
Will_H's Avatar
im having a similar issue with my Tilton also wont go into gear for 3rd or 4th shifting the car normally. Called Tilton and he told me to keep adjusting the pedal, haven't messed with it since.
Old Aug 18, 2009 | 06:32 AM
allvtec's Avatar
i also have tilton twin disc ceramic clutch on a b series transmission with tilton master and hydraulic throwout bearing and also flow control valve. and having problems going in 2nd gear .
Old Aug 18, 2009 | 06:50 AM
tony1's Avatar
If you only have problems in 1 gear, it's likely a transmission or shifting issue. If it's in all gears, it's probably the clutch.
I've seen the Tilton cerametallic clutches warp floaters pretty bad. If the clutch is used, i'd pull it and inspect everything.
Old Aug 18, 2009 | 07:20 AM
allvtec's Avatar
if the Tilton cerametallic clutches has warped the floaters. what would be the symptoms , i did noticed one side of my clutch is blue and the other is like new ? i also have used 3 diffrent trannys and grinds on 2nd gear and havent really went for the rest of the gears.
sloturbohatch
Jul 14, 2014 05:33 PM
raverx3m
Transmission & Drivetrain
Jan 27, 2012 08:12 PM
dragonkx
37
Jun 2, 2010 09:04 AM
rough_draft
Dec 5, 2004 09:01 PM
sykotik sol
Dec 3, 2002 07:54 PM
