help: d series clutch question...............help please!
ok, heres what happened i was driving and i went to push clutch in to shift and it sunk to the floor, i lifted it back up by hand and it was really stiff!....it wouldnt let me shift at all........so i took a guess thinking it was the throw out bearing, and i rip her down and took it out, looked good, but i replaced it anyways.......i did not remove pressure plate or clutch disc because they looked fine.....so my next guess is its the springs in the clutch disc...i bled clutch line and theres no air at all......if you guys think any differently your thoughs are appreciated, thanks in advance........................................... .mike
Re: help: d series clutch question...............help please! (sykotik sol)
not a really informed post on my part, but could your slave cylinder need rebuilding?
Re: help: d series clutch question...............help please! (hanson said)
Sounds like your clutch master slave cylinder to me.
I had this exact same problem about 2 years ago. Replaced my clutch master cylinder and never had the problem since.
[Modified by spektrum, 11:38 PM 12/3/2002]
Re: help: d series clutch question...............help please! (Paranoid Android)
check slave cylinder, then master cylinder. betting its the slave cylinder. good luck
s1ngle
13
09-21-2005 12:01 PM
