93 Del-Sol Question
Old Aug 25, 2002 | 04:25 PM
YEL-MEL's Avatar
Default 93 Del-Sol Question
I HAVE A QUESTION.
I HAVE A 93 DEL SOL SI. SEEMS TO ALWAYS RUN FINE HOWEVER SOMETIMES AFTER SITTING AT WORK ALL DAY IT WILL NOT START , OR WILL START AND CUT OFF RIGHT AWAY. IT TURNS OVER FINE, JUST WILL NOT FIRE UP. I have had this problem mabye only 4 times over the past 4 months , but twice in the past 2 days. Mabye the hot temps here outside have something to do with it ?
I think it may be the distributor , fuel pump or mabye the main relay, but I am not a mechanic at all. I am sure if it take it in I will be ripped off for more that it needs.
If anyone has any info or things I could check please let me know ,it would be greatly apreciated. The car has 125,000 miles on it and would like to keep it running without spending a ton money.
Thanks .....
Old Aug 25, 2002 | 07:50 PM
CrotchRocket's Avatar
Default Re: 93 Del-Sol Question (YEL-MEL)
If the starter doesn't engage, try to hit it with a metal rod or a club. It should work. I think you need a new starter.
twj815
12
May 27, 2020 09:39 PM
Dahhhbeed
Engine Management and Tuning
Aug 14, 2016 11:06 PM
HezaDelsol
28
Nov 27, 2011 03:47 PM
Matthew_zero
11
Mar 31, 2010 09:13 AM
WEEZY034
Jul 28, 2008 05:16 AM
