Window Problems in the EM1
Old Aug 15, 2009 | 12:08 PM
tiptopEBPcivc's Avatar
Icon3 Window Problems in the EM1
Hi honda tech, havnt been on in awhile..............
but im running into a problem with the 99 honda civic si, the Pass side window wont go up or down....
how do i fix it? and if you give me answers give me very detailed answers, its something ive never done before ((electric and what not))
things i have done...... hooked the window motor to the battery to check to see if it works and it does. thats how i got it back up..... checked the fuses under the dash and under the hood. none are blown, but replaced with +5 more amps just to make sure.
what are next steps to solve..... again as stated above give me detailed instructions........ i want to do this on my own, but if i cant get the answers its going to a tint shop here in town to have them do it.
thanks
Old Aug 15, 2009 | 12:42 PM
Former User's Avatar
Default Re: Window Problems in the EM1
Double check whether fuse 10 under the dash is blown. Otherwise, one possible cause is a bad driver's or passenger's window switch.
Old Aug 15, 2009 | 01:38 PM
okay, fuse is good, i took the switchs out of the working EM1 (((((i have two)) and it still didnt work. what next?
Old Aug 15, 2009 | 01:41 PM
Cln94EG1's Avatar
Next would be the window motor inside the door
Old Aug 15, 2009 | 01:43 PM
gearhead16's Avatar
check for power at the motor when you hit the switch. and did you check your fuses?
Old Aug 15, 2009 | 01:45 PM
Is the main switch on the driver's door turned off?
Otherwise, you need to check the wires. Do you have a multimeter?
Old Aug 15, 2009 | 01:47 PM
i have a multimeter i have no idea how to use it................
again people read before you post ((not being a ***** just saying)) but i have checked the motor, i have checked the fuses............... and i have checked the switchs now.................................. and i checked also to make sure there is no binding problems...........
but if you are going to tell me how to use a multimeter.... please be detailed.
thanks for the replys so far
Old Aug 15, 2009 | 01:51 PM
For instructions, post a clear picture of your multimeter. The first step is to check for voltage at terminals in the master and passenger window switch connectors.
gearhead16's Avatar
use a test light then
Old Aug 15, 2009 | 02:00 PM
im real good with the test light, i just hate reading the mulitimeter.
Old Aug 15, 2009 | 02:04 PM
The test light is fine for only the most basic voltage tests, and you can't use it to check continuity. Seriously, the multimeter is not much more difficult to use and is a much more powerful tool. Don't be afraid to learn something new.
Old Aug 15, 2009 | 03:11 PM
well what do i need to do to check the wires? fuse to window motor?
fuse to switch?
Old Aug 15, 2009 | 03:26 PM
With the key in ON(II), check for voltage at terminal A6 of the main switch connector (wire harness) and terminal 1 of the passenger switch connector (wire harness). Use metal frame under the dash as ground for these tests.
ekkscott
Honda Civic (2001 - 2005)
Feb 5, 2012 09:27 AM
Figuroso08
Sep 12, 2010 07:42 PM
Silvertc
14
Nov 29, 2009 05:57 AM
Nighthawk R18
Honda Civic (2006 - 2015)
10
Apr 26, 2008 12:19 PM
ColMustard
Dec 3, 2007 10:13 AM
