install needed
I need help with installing shocks/struts and springs for a 89 CRX SI. Im sure im in the wrong fourm for this but i need help. If interested please IM me.
Sacramento CA
Sacramento CA
look in the suspension thread. i believe one of the mod's patrick if i remember correctly did a write up of koni's and ground controls. same principal would apply to stock shocks. but, for the front.. take out the fork bolt, and then the bolt in the top of the fork that holds the shock in. then take out the two nuts up top that hold the assembly in. then the shock and spring should fall down. put your spring compressor on the spring, and remove the shock. reverse the process to reinstall. for the rear.. take out the bottom bolt of the strut, and the bolt closest to the brake rotor. loosen the inside bolt on the control arm also. the control arm should fall down a bit. then, take the two nuts out of the top, and the assembly should fall down. same thing with the spring compressor, and reverse this also for the installation of new equipment. i don't have any pics, but there it is in a nutshell.
it is really easy but DO NOT DO NOT DO NOT remove the middle bolt top of the strut remove the two outer bolts but not the one on the middle.
The only time you remove the middle bolt is when the you have the strut in the compressor. there is a nut and a hex you put a hex in the middle and loosen the nut while compressed.
ps what is it that you are doing installing coilovers,stock springs, lowering springs, or installing new struts
Im installing Tokico Illumina they also come with lowering springs.
so the springs are already on if so then just do it yourself if posible
here are the basics with pictures
https://honda-tech.com/forums/acura-integra-type-r-8/koni-shock-install-56k-burn-891136/
see that's the problem i don't know how to install them. the write ups I've seen are all on acuras not CRX. My fear is gettin into it and eff-en something up cause im looking at a thread on integra.
few letters and a few clicks later we have:
http://ef-honda.com/ben/EFlowering.php
THUS WE HAVE THE GENERAL IDEA HOW TO INSTALL CHIT ON OUR CARS
YAY.
YAY.
Bruce Banner
Jun 29, 2007 08:19 AM
etp72
14
Jul 18, 2003 12:33 PM
