headgasket problems
Old Aug 25, 2002 | 02:44 PM
ketchup_gsr's Avatar
Default headgasket problems
Well i have an r-ideal head gasket from fmax, it's to lower compression. Well it seems sluggish, not too much, but it is a little slower on acceleration. The idle is funny too, i used to idle at like 800-900 rpm, now it's idling at like 600 and dips to like 400 or so every now and then. Also if i didn't install this thing right, will my engine leak oil? it's not just leaking down, as in dripping off the oil pan, it's also dripping off the front lower suspension arm, the one that's just like 3 inches behind the oil pan... yikes, i have problems, can any offer any suggestions?
Old Aug 25, 2002 | 04:10 PM
BoredNStroked's Avatar
Default Re: headgasket problems (ketchup_gsr)
Buy an new head gasket and have a professional install it......You "f"ed up some where.
Old Aug 25, 2002 | 04:37 PM
tinkerbell's Avatar
who installed it? how long ago? where is the oil leak coming from?
what bolts/studs did you use?
what torque?
did you resurface the head?
etc etc...
t..
Old Aug 25, 2002 | 11:10 PM
Default Re: headgasket problems (tinkerbell)
well it's leaking from the timing belt side... it's leaking, looks like, inside the timing belt cover.. i've checked for leaks everywhere else and it's mostly dry...you think it could be the crank oil seal from when the timing belt came off? I don't want to pull that thing apart again.
ryaldin
Jan 26, 2015 11:39 PM
91crx-jace
Apr 22, 2012 04:36 PM
skipper28-DC
Feb 25, 2012 10:17 PM
protopro88
Jun 17, 2011 02:17 PM
MNturbosi
Apr 9, 2004 04:57 PM
