Rear Disc Brakes for 98 Civic EX
Old Aug 13, 2009 | 08:53 AM
TUR3Ovtec's Avatar
Default Rear Disc Brakes for 98 Civic EX
OK, so just today in my yard i got a 94 Integra w/ ABS. Now my question is does it matter if the integra has ABS or not and wether its a 2dr or 4dr? The one i got here has ABS and is a 4dr... Can i just still pull of the spindle and everything and be ok, just use a prop valve from a 92 integra ls? Thanks for any input, i want to get it done ASAP!
Old Aug 13, 2009 | 10:41 AM
TUR3Ovtec's Avatar
Default Re: Rear Disc Brakes for 98 Civic EX
anyone chime in please... cars sitting here and its buggin me the brakes are still on it LOL
Old Aug 13, 2009 | 10:44 AM
kaiba's Avatar
2, 3, 4, 5, 10 or 20 doors. Doesn't matter it will bolt on just find. Regard abs or not.
Old Aug 13, 2009 | 10:45 AM
kaiba's Avatar
I would use the 99-00 si proportioning valve. 6th gen civic valve are different design.
Old Aug 13, 2009 | 11:12 AM
TUR3Ovtec's Avatar
Great, thanks alot dude. I thought the 00 Civic Si's came w/ ABS... **** i had one and i dont even remember if it had it or not...wtf. LOL... I was told to use the older DA prop valve... but i might have a Si one layin around the yard. Thanks for your help bro!
Old Aug 13, 2009 | 11:37 AM
kaiba's Avatar
For the 88-95 civic. The DA prop is required. 96-00 use the 99-00 Si. Remember to upgrade you brake booster and master cylinder also.
Old Aug 13, 2009 | 06:05 PM
TUR3Ovtec's Avatar
really? i didnt know all that has to be changed... i thought those could of been kept the same... im guessin off the Si also?
Old Aug 13, 2009 | 08:53 PM
808Army's Avatar
im still useing my stock civic one with no trouble. only touble had with e-break cables pain in azz put on.
Old Aug 13, 2009 | 08:54 PM
TUR3Ovtec's Avatar
i was reading on that FAQ thing on here and i guess its easier to use a Si ebrake cable rather than a integra one... i guess its a bolt on either way... im still tryin to figure **** out to see if i want to jump in on this or not...
Old Aug 13, 2009 | 09:17 PM
EL Vap133's Avatar
The 99-00 Si e-brake cables are a direct fit.
You can use the 99-00 Si prop valve or the 96-00 dx prop valve, they are the same and share the same part number.
You have the EX so you should already have the 7/8 MC, I wouldn't change it.
The 99-00 Si did NOT come with ABS, you can still use those Teg brakes, just take the ABS wires off. The 2-door and the 4-door share the same size rear trailing arms.
Old Sep 13, 2009 | 11:00 AM
rehaf's Avatar
Glad to see this, I picked up a '00 dx hatch prop valve at the local salvage yard for $20 for the upcoming swap on my '00 ex.
Old Sep 13, 2009 | 01:19 PM
94EG8's Avatar
Seagull Management
You can also use a '94 - '97 non ABS Integra prop valve, direct bolt on.
You can also use a '98 - '01 non ABS Integra unit here.
sinyce
Aug 2, 2016 10:48 AM
mrbigg9032
25
Jan 14, 2013 09:49 AM
Ej8_KiD
Suspension & Brakes
Apr 2, 2011 07:06 PM
mrbigg9032
Suspension & Brakes
21
Dec 8, 2008 08:01 PM
willyboyK20
Sep 22, 2003 08:51 PM
