Transmission & Drivetrain Gearboxes, Differentials, Clutches
HELP! TRANNY LEAK NEED HONDA VETERANS ON THIS
Old Aug 12, 2009 | 01:48 PM
jonnyt1130's Avatar
Default HELP! TRANNY LEAK NEED HONDA VETERANS ON THIS
Hey honda-tech i need your help desparately. so i take my car around the block for the first time ever, and i pull back in my driveway and noticed that i was leaking transmission fluid..so i take a look to see where its coming from and it deffinatley looked like it was coming out of my drivers side axle where it meets the tranny..soo i figured must be that axle seal, so i tear my car back apart and take out the axle and put in a brand new seal ( i bought one for a 91 integra ls..idk if all the b series cable trannys have the same one?), put it all back together and take it for another spin just to find it still leaking just as bad as before. i have no idea what to do now..i have a cable supposevly b16 tranny in my crx with of course b series axles...i need this car running now that my DD just **** the bed..please help
Old Aug 12, 2009 | 02:11 PM
Aquafina's Avatar
Default Re: HELP! TRANNY LEAK NEED HONDA VETERANS ON THIS
Measure the axle...
I'm assuming you installed the seal correctly.
Old Aug 12, 2009 | 02:15 PM
jonnyt1130's Avatar
what am i looking for when i measure the axle? everything lines up flush..and i installed the seal flush with the transmission even all around
Old Aug 12, 2009 | 04:16 PM
Honda Bull's Avatar
Does the halfshaft seat into the trans the entire way?
Old Aug 12, 2009 | 04:22 PM
jonnyt1130's Avatar
as far as it can go
Old Aug 12, 2009 | 05:52 PM
Aquafina's Avatar
The outer diameter where the seal rides.
Old Aug 12, 2009 | 09:18 PM
Mista Bone's Avatar
D Tranny Guru
What seal are you using?
Which midhaft???
IIRC 94+ midshaft uses a smaller seal.
Old Aug 13, 2009 | 08:09 AM
Clerique's Avatar
Make sure the shaft is very smooth and free of rust. A little rust will act like sandpaper on the seals and wear them extremely fast.
Granted you have the correct seals in the first place.
Old Aug 13, 2009 | 09:44 AM
jonnyt1130's Avatar
i believe i have a DC halfshaft and i had put in an axle seal for a DA so i just ordered the axle seal for the DC's and its coming in tomorrow i'll keep you guys posted
Old Aug 13, 2009 | 11:06 AM
Mista Bone's Avatar
D Tranny Guru
Axle seal for a 88-00 D series????
Yes it is.
Old Aug 13, 2009 | 12:39 PM
jonnyt1130's Avatar
its b series
Old Aug 14, 2009 | 12:40 PM
jonnyt1130's Avatar
ok guys so i took it all back apart and put in the new axle seal for a DC and after i took it for a ride it didnt leak one drop! thanks for everything for all who helped..greatly appreciated
Old Aug 14, 2009 | 06:38 PM
Mista Bone's Avatar
D Tranny Guru
Originally Posted by jonnyt1130
its b series
But the seal was intended for D series.
PL3 is the middle code.......88-91 D series 5 speeds are PL3, understand?
Old Aug 14, 2009 | 09:13 PM
jonnyt1130's Avatar
well PL3 was the middle code but i dont get your logic but ill take your word for it
Old Aug 15, 2009 | 02:15 PM
Mista Bone's Avatar
D Tranny Guru
Not my logic, Honda's
When I ordered seals for a GSR tranny I did I was like WTF, they sent the wrong seal, but it was right.
Old Aug 30, 2009 | 05:42 AM
ORANGE EF's Avatar
i have a oil leak from the same spot. i have a ys1 case with hydro gears and im using a 94+ half shaft and axles in a 88 hf crx. everything fits as good as a da half shaft and axles. so basically im supposed to use the seal to the half shaft right?
f22 killer
Jul 27, 2010 07:47 PM
jonnyt1130
20
Aug 25, 2009 07:47 AM
antz92
Jul 4, 2008 09:15 PM
civicjoe8
Apr 11, 2006 08:52 PM
Batoutahell
Feb 27, 2005 01:32 PM
