Help! D15Z1 Vtec-E motor in 99 Civic
Old Aug 11, 2009 | 03:39 PM
1SikEagle's Avatar
Default Help! D15Z1 Vtec-E motor in 99 Civic
i got a d15z1 motor in my 99 civic lx, its running on the y7 computer and the y7 complete intake manifold with the y7 injectors, what do i need to make it run good, right now it wont go over 5k rpm.. i know i need a ob2b jumper and run the d15z1 p07 computer, but do i need the vx(d15z1) injectors? do i need a special o2 sensor??? or can i just throw the y7 cam in it and be done with it???
Old Aug 11, 2009 | 04:05 PM
94EG8's Avatar
Seagull Management
Default Re: Help! D15Z1 Vtec-E motor in 99 Civic
You will need to use everything from the Z1, including the wideband O2 sensor and ECU if you want it to run right. You will need an OBD2 to OBD1 jumper harness to use the ECU as well. Some wiring will need to be done (wiring Vtec, EGR, 5 wire O2 sensor, IACV fix. You will also want to run the VX tranny for optimal mileage.
Old Aug 12, 2009 | 11:49 AM
1SikEagle's Avatar
what do you mean by idle air control valve fix??? also how do i wire the egr in??
Old Aug 12, 2009 | 08:39 PM
1SikEagle's Avatar
ttt
Old Aug 13, 2009 | 01:42 PM
94EG8's Avatar
Seagull Management
IACV fix:
You will need to pick up a helms manual for a '92 - '95 civic for the EGR valve wiring diagram.
Old Aug 13, 2009 | 11:10 PM
1SikEagle's Avatar
good info? what would happen if i put the y7 cam in it??? since im running on y7 computer and y7 complete intake manifold.
Old Aug 13, 2009 | 11:17 PM
thumper64's Avatar
non-VTEC cam going into a VTEC head. I don't think it's going to work. If you're after more power, drop a Z6 in. Don't mess with swapping heads and junk, the VX engine was made light and it's weak because it wasn't meant to put out a lot of power. Minime swaps aren't really logical because the D15Z1 bottom end will net a low comp ratio with a regular VTEC head.
Old Aug 14, 2009 | 08:32 AM
1SikEagle's Avatar
i just want it to run good without the headache. i figured cam would be easiest. z6 cam? and y8 computer??
Old Aug 15, 2009 | 12:32 PM
1SikEagle's Avatar
^Bump?
Old Aug 23, 2009 | 10:07 AM
1SikEagle's Avatar
why would i have to do the iacv fix if im running the y7 obd2 intake manifold??
Old Aug 23, 2009 | 01:08 PM
94EG8's Avatar
Seagull Management
Already sort of answered this in your PM. But to further clarify: The VX ECU looks for a 2 wire IACV. Even if you keep the original Y7 IM and throttlebody with the 3 wire IACV on it the ECU wont be able to do anything with it and you will have an idle that fluctuates from about 800rpm to 1500rpm.
Sphorti1
Mar 1, 2016 04:54 PM
gitarman2
13
May 27, 2013 12:05 PM
da59block
Nov 16, 2011 11:25 AM
kyden
Sep 28, 2004 04:18 PM
