Which engine to swap into del sol?
Old Aug 11, 2009 | 11:24 AM
Jdm John's Avatar
Default Which engine to swap into del sol?
Hey I'm thinking about taking out the z6 and putting something bigger in. Which route should I go? b16? Gsr? LS/Vtec? B20/Vtec. I would just to like to hear your opinions. And which one would be the cheapest if I swapped it in myself? Thanks in advance.
Old Aug 11, 2009 | 11:29 AM
EFbomb's Avatar
Default Re: Which engine to swap into del sol?
LS1 lol
What do you want to do with the car? Just make more power? do you travel lots of highway? Autocross? Drag? Stay NA or go forced induction ?
There are alot of variables that can determine what would fit you best. We need more info to give an informative reply.
otherwise everyone will say K20 because its the fad right now.
Old Aug 11, 2009 | 11:32 AM
ALLxMOTOR EG's Avatar
Vietnamese!
LS motor.
Old Aug 11, 2009 | 11:44 AM
Jdm John's Avatar
Well I want to stay NA for now. And I don't travel lots of highway nor autocross or drag. Just want to go faster
Old Aug 11, 2009 | 12:52 PM
Since 1983's Avatar
swap in an LS with a gsr/b16 tranny, it will be significantly quicker
Old Aug 11, 2009 | 01:12 PM
ImmaculateDelSol's Avatar
the easiest swap would be the b16a3, as it comes right out of the delsol VTEC and should be nice and easy to swap in with the usual parts (ECU, harness, axles?, etc). its definatly a power increase over the z6's 140ish hp but the b18 shouldnt be too bad to swap for you either if you really want that extra displacement. as someone previously noted, the fad is the K series engines which are nice, but awfully pricey and not the easiest to swap into the sol's as youll probably run into some ground clearance issues and a whole mess of OBD 2 wiring (if you arent already a 96-97 sol). Id say your best choice for overall ease of installation and wallet is that b16a3 but its not as big of a HP increase as say the B18, K20, H22, etc.... hope it helps
Old Aug 11, 2009 | 01:50 PM
96DelSol's Avatar
Ls motor ftw!
Old Aug 11, 2009 | 08:57 PM
Jdm John's Avatar
So with ls should I go with a1 or b1 cause I've heard different things about both.
Old Aug 11, 2009 | 09:36 PM
shak3yb0n3z's Avatar
the b16a2/a3 are the stock motor for the del sol vtec model. a3 is obd1 and a2 is obd2. they are definitely a fun car with this engine.
LS swap can be fun too and is definitely affordable and leaves room to upgrade down the road if you decide to go boost or run LS/VTEC.
Old Aug 11, 2009 | 10:09 PM
-__-'s Avatar
^^what he said. an LS with a GSR transmission is perfect. If u run the B16 transmission you will be screaming down the highway at a much too high RPM. with the LS later down the road u could VTEC it or boost it as the LS motors handle boost well. oh yeah and u should throw the b18b1 in it
Old Aug 11, 2009 | 10:14 PM
jshaw23's Avatar
Go with an h22, easy swap to do yourself and it will blow the b's out of the water. just my opinion, i love my h22 civic.
NoobieDude
Jan 5, 2010 03:02 PM
drunknmonkey18
Nov 9, 2004 06:19 PM
Steve86
Jul 10, 2003 09:27 AM
gshockbreaker
Apr 28, 2002 10:16 AM
xXsarcasmXx
Dec 11, 2001 10:33 PM
