Need help with timing???
Old Aug 10, 2009 | 11:29 AM
scrambled_EG's Avatar
Icon2 Need help with timing???
94 civic cx with a d16z6 and obd1 gsr harness. Everything stock.
I was adjusting my valves and wanted to check my timing also because smog was coming up. After checking timing (with the service connector jumped), I noticed that timing was off. Checked crank pulley and cam sprocket but everything lines up at tdc. Can't move distributor anymore because it's maxed out ( moved forward all the way...forget if that was advanced or retard lol). But even while moving the distributor either way, the mark doesn't align.
My only conclusion is that it is the ecu because it's a cx ecu (bought the car that way with that ecu..previous owner didn't have a p28). Any suggestions?? Need fixed before smogging.
everything works fine (idle, etc..) just w/o vtec and slow take off.
Old Aug 10, 2009 | 11:31 AM
ColMustard's Avatar
Default Re: Need help with timing???
I would def try and get another ecu. Find a friend that has a ecu similar to your setup or a p28
JohnnyEF
Feb 10, 2010 06:09 PM
---SPEED-DEMON---
Engine Management and Tuning
Apr 1, 2009 12:14 AM
krysted9354
Dec 21, 2008 12:05 PM
wilsel
Mar 23, 2005 05:37 PM
cruzersi99
Jan 29, 2003 09:13 AM
