Where on the oil pan do I get my fitting welded?
Old Aug 25, 2002 | 04:56 AM
DR. ON POINT's Avatar
Banned
Default Where on the oil pan do I get my fitting welded?
Juat like the topic says. Its a 10 AL fitting. Any one have pictures?
Old Aug 25, 2002 | 04:59 AM
rjardy's Avatar
Default Re: Where on the oil pan do I get my fitting welded? (On Point EK!!!!!!!!)
It needs to be up high, higher than the oil line would be when the pan is full.
Rob
Old Aug 25, 2002 | 05:24 AM
bigTom's Avatar
Default Re: Where on the oil pan do I get my fitting welded? (rjardy)
as close to the top of the oil pan as u can get it to be... if u put it lower the oil will back into the line and therefore the line will become backed up
Old Aug 25, 2002 | 06:16 AM
EE_Chris's Avatar
Default Re: Where on the oil pan do I get my fitting welded? (ek9t)
There is a little tip about placing it across from a crank main. As in, don't mount it so that the crank itself is swinging directly in front of it, as this could cause turbulence, thus hindering oil return.
This was brought to you from Honda Builder's Handbook, Vol I.
Old Aug 25, 2002 | 06:43 AM
gsrroots's Avatar
Default Re: Where on the oil pan do I get my fitting welded? (EE_Chris)
I want to know this myself.....where are some pictures
Old Aug 25, 2002 | 08:16 AM
h0mesk1let's Avatar
Default Re: Where on the oil pan do I get my fitting welded? (gsrroots)
make sure you can get to all the studs/bolts and the return isnt in the way of puting the pan on
Old Aug 25, 2002 | 08:40 AM
Teg4e's Avatar
Default Re: Where on the oil pan do I get my fitting welded? (EGb18cT)
I loosely attached my downpipe to the turbine side when marking my oil pan. It's hard to be sure of a good placement without doing this. The advice to tap up high is good, as we all know gravity is doing most of the work in the return line. Here are some excellent, up-close pics courtesy of Dustin's site:
http://imglib.************/index.cgi?cmd=viewimage&id=32
http://imglib.************/index.cgi?cmd=viewimage&id=33
The Dirty EJ1
Mar 18, 2008 09:27 PM
toolowsol
Feb 9, 2006 01:52 PM
B18c1turboedEK
Feb 21, 2005 10:32 AM
AF-b16a1
Aug 3, 2004 02:24 PM
torr
Apr 14, 2004 07:48 AM
