big 3..where's the positive on the alternator?
Old Aug 9, 2009 | 10:09 PM
97civic123's Avatar
Default big 3..where's the positive on the alternator?
i have a 96 civic dx..was doing the big3..
am i connecting the wire from the positive battery to the nut with the grommet? is that the positive connection on the alternator?
Old Aug 9, 2009 | 10:30 PM
Davus's Avatar
Default Re: big 3..where's the positive on the alternator?
Yep, that's it, and then the ground is just the case itself, which goes through the alternator bracket through the engine and to the engine-to-chassis wire, which you upgraded.
Old Aug 10, 2009 | 04:31 AM
97civic123's Avatar
is it better to run the positive wire with an inline fuse direct to the car battery or should i use the use box? what size amp do i need to use here if inline. if thru the fuse box, which wire?
Old Aug 10, 2009 | 04:37 AM
Davus's Avatar
*wakes up* To the battery would be a more direct route, current wouldn't be limited by the capacity of the fuse box. As for amperage, stock alternator puts out about 65 amps max in your particular setup, so 60-70 or less. Others may say different some reason or another.
Old Aug 10, 2009 | 04:42 AM
97civic123's Avatar
thanks dude..will give it a try
Old Aug 10, 2009 | 06:11 AM
twentyhurtz's Avatar
when i upgraded the big 3 on my civic, i actually ran 1/0 gauge from the alt straight to the battery and used an anl fuse holder with 150a fuse. the oem line and fuse is rated at 80, you can upgrade to a 100a fuse, but keep in mind that wire is small and generally when you up your alternator you are usually at least doubling your power from alternator, the stock wire is no longer sufficient.
Old Aug 10, 2009 | 08:24 PM
97civic123's Avatar
once i add an O-ring terminal to the positive on the alternator, what are you guys using to cover the terminal since the grommet won't fit over it anymore..i guess unless cut.
Old Aug 10, 2009 | 09:25 PM
Davus's Avatar
I bought some boots from eBay that slide over. This one in particular:
http://cgi.ebay.com/ebaymotors/2-2-0...ssoriesQ5fGear
I'd snap a pic, but the '96 is in Seagoville.
Heisenberg
18
Mar 8, 2015 07:16 AM
EG_SICKZ
10
Jun 14, 2012 01:45 AM
91-lsvtecsi
Mar 15, 2012 04:14 PM
1991civicb16
Audio / Security / Video
Jul 12, 2011 07:20 PM
baca00ex
Oct 20, 2010 09:53 AM
