When Upgrading the Alternator power wire....
Old Jul 5, 2011 | 10:45 PM
1991civicb16's Avatar
Default When Upgrading the Alternator power wire....
I just got a High output alternator and my rpms bounce when my bass hits. So i was curious i followed the power wire from the alternator and it goes to the black box under the hood which only looks like a fuse box. Can i just cut the wire and run my 0 gauge wire from the alternator with an inline fuse to the battery? this is in a 91 civic hatch.
Old Jul 6, 2011 | 01:06 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: When Upgrading the Alternator power wire....
Yes you can. But you can fuse it and go straight to the battery.
Old Jul 6, 2011 | 06:29 AM
baca00ex's Avatar
I switched out the battery terminals and added the 0 gauge, didn't want to cut anything incase I sold the car in the future. I'm using 100 amp inline fuse, not sure if you'll need something bigger with an high output alt. Don't forget to upgrade your grounds with 0gauge as well, I've got my battery negative grounded to the engine block as well as the chassis and I switched out the 2 grounds on the block with 0 gauge.
These are the terminals I'm using for pos/neg, have 2 0 guage and 2 8gauge (2 8's can be used for your starter/fusebox). That way you don't have to cut anything, just add the 0 gauge.
http://www.amazon.com/Tsunami-BT703-...9963149&sr=8-3
Old Jul 6, 2011 | 07:29 AM
rjr162's Avatar
Also make sure you have the belt tight enough. More load on the alternator = harder to turn the amp, so when you're pulling a lot of power the alternator becomes harder to turn which means a belt not tight enough will slip reducing the power output from the alternator
Old Jul 12, 2011 | 04:21 PM
Ok guys i got the wire on but im having a possible problem. With the new wire it blows the black box fuse but the wire has a 120 amp fuse so thats fine. Also since the change ive noticed my car is kinda jolting in higher rpms when i am lightly touching the gas pedal.
Old Jul 12, 2011 | 05:17 PM
fcm's Avatar
fcm
Old Fart
First, you do not need a 0, [1/0] gauge cable for your alt., if your alt. is a 125A H/O all you need is a 4 gauge, [good to 150A].
Replace the 120A fuse with a 150A fuse. 94
Old Jul 12, 2011 | 07:20 PM
Never mind it only blew a fuse the first time and that was a mistake i made, but what about the hesitation thing any ideas?
Also my alt is 165A so im guessing 1/0 is fine then.
Heisenberg
18
Mar 8, 2015 07:16 AM
baca00ex
Oct 20, 2010 09:53 AM
97civic123
Audio / Security / Video
Aug 10, 2009 09:25 PM
92HB_HB
Aug 23, 2006 06:57 PM
