NEED HELP WITH A MOUNT QUESTION!!
Old Aug 9, 2009 | 10:26 AM
ChinitodeNJ's Avatar
Default NEED HELP WITH A MOUNT QUESTION!!
So I bought a 96 ex shell and later bought a 98 GSR to swap in it. So as I tryed to make sure I had the correct mounts I noticed the mount on the driver side did not fit to the pins. So at first I thought I had the wrong mount but then later I realized it seemed like someone changed the piece with the pins on it. So my question is where is the piece with the pins from and what mount fits on it?
Old Aug 9, 2009 | 10:52 AM
Default Re: NEED HELP WITH A MOUNT QUESTION!!
bumpp
Old Aug 9, 2009 | 11:37 AM
bummpp
Old Aug 9, 2009 | 12:26 PM
94EG8's Avatar
Seagull Management
mount and bracket need to come from a '99 - '00 Civic Si.
Old Aug 9, 2009 | 12:36 PM
that is the mount and bracket from a 99-00 si.....
Old Aug 9, 2009 | 12:44 PM
94EG8's Avatar
Seagull Management
When I said mount I actually meant the 2 post mount attached to the block itelf.
98civdx's Avatar
Master Detailer
i dont think its from a 99-00 si, its most likely from the integra
Old Aug 9, 2009 | 12:53 PM
ohhh ok my bad thanks
Old Aug 9, 2009 | 12:54 PM
94EG8's Avatar
Seagull Management
Doesn't appear to be from an Integra, they use a 3 post mount, which is why you need the Si mount and bracket in the first place.
Old Aug 9, 2009 | 12:56 PM
98civdx's Avatar
Master Detailer
opps, your correct, thank you for correcting me.
i was thinking of my buddys mount, 2 studs and a bolt.
Old Aug 10, 2009 | 02:11 AM
94EG8's Avatar
Seagull Management
Actually upon closer inspection you may be right. I see a third hole.
Old Aug 10, 2009 | 01:45 PM
98civdx's Avatar
Master Detailer
one way to find out. op is that third hole in front of the 2 studs threaded or have a bolt underneath??
if it is you have a integra mount, not civic.
_kiid
Texas -OK -LA (Sales)
28
Aug 11, 2009 01:29 AM
donkiman
Jul 18, 2005 03:46 PM
lscoupe
Apr 24, 2005 11:15 PM
bretx0r
Mar 24, 2003 03:27 PM
deviant1
Oct 15, 2002 07:00 PM
