shift knob
hey guys i have a 1999 civic dx sedan, and my shift **** is fine but the shift boot is probably broken, because i can see the metal part of the shifter, there is a gap between the actual shifter and the shift boot so idk how i can get rid of that gap other than buying a new shift boot.
put the top of the inside outboot (skinny part) where you want it, zip tie it tight. trim off excess TIEwrap. flip boot back over and put into place replace ****
alright, so honda prelue shift boot to the **** is square... i've tried unscrewing the shift **** to get it off but the boot justs twists with it till it won't twist anymore and it won't disconnect. how do i get it off?
Pull down on the collar of the shift boot first to disconnect it from the ****.
i have same problem i just stuck my hair tie under it. just get a new shift boot and zip tie underneath it before you put the new one on. pwjdm sells them for cheap like 30 bux maybe u can even get it for 20. or you can get the honda one i think its like 50. theyre easy to remove you just have to take that whole platform off. the center console thingy next to the shifter and ebrake
PatrickGSR94
Apr 4, 2010 09:03 AM
