Just got a invertec 155, need to rewire the power socket
Old Aug 8, 2009 | 02:19 PM
RACEPAK's Avatar
Default Just got a invertec 155, need to rewire the power socket
hello everyone
i just got a lincoln invertec 155 from the US and i need to rewire it to fit my standard wall sockets(i live in israel 220v wall socket), and i have no idea how to do it,
its got a 120/230V auto reconnect input power.
can anyone help?
thanks
Old Aug 8, 2009 | 02:40 PM
SD_Lurker's Avatar
HT White Ops
Default Re: Just got a invertec 155, need to rewire the power socket
ummm ****.... well I can tell you the welder is setup for a 110/115 outlet. I find it hard to believe your STANDARD plugs are 230. I mean how the hell would you run small radios and other little things?
ok with that being said I want you to go to your local hardware store and just buy the standard isreal plug. Then take a picture of it on the back. I'm gonna go check out your plugs on google.
Old Aug 8, 2009 | 02:44 PM
xxbulaxx's Avatar
A lot of countries in Europe run 220ish standard.
Old Aug 8, 2009 | 04:48 PM
pk386's Avatar
http://www.kropla.com/electric2.htm
Israel runs 220VAC 50hz
according to this
PDF LINK!
http://content.lincolnelectric.com/p...ture/e2141.pdf
Your welder should work... the cover that the power cord in to should come off and there should be some terminals to connect/re-arrange and set the welder up for 220VAC. (or there may be a switch on the back to select between 220 and 120 like PCs have)
I would find an electrician to help you out if you don't know what your doing....
120 will tingle a little
220 will HURT you....
(and yes I know it takes less than 1A at ANY voltage to kill you)
Goold luck!
Old Aug 8, 2009 | 08:16 PM
SD_Lurker's Avatar
HT White Ops
Well with the new inverter machines all you need to do is wire the cord with whatever plug you please and the machine recognizes what power your using. At least that's how the Miller inverters work.
Old Aug 8, 2009 | 11:21 PM
awill4x4's Avatar
Here in Australia, our standard voltage for home use is 240 volts. (single phase)
Regards Andrew from Oz.
Old Aug 9, 2009 | 02:12 AM
Stachi's Avatar
Dude, your wall socket already looks like you tried to hammer that plug in Get a local electrician to cut your original plug and put a new one on
And yeah, it's true, most european countries have 230V, just different plugs. 400V/16A Three Phase sockets are also quite common in German Garages..
Marc
Old Aug 9, 2009 | 06:30 AM
RACEPAK's Avatar
nah, it just how it looks, (for round or square pins)
Old Aug 9, 2009 | 10:35 AM
abnaasefmb's Avatar
just cut the end off, find out what wires went to the II on the american plug and wire them to your two oo. the one on the bottom is the ground. do this the right way, solder and heat srink wrap. make sure the wall plug is wired for enough amps, you dont want to trip breakers or burn your house down. or you could be retarted and use one of these. http://www.target.com/Embark-All-in-...adapter&page=1
**** like this was always starting fires when i was in Iraq. good luck and enjoy. ps america is the only place that runs 120v 60hrz that i've ever been.
Honda4life777
Jul 23, 2009 05:36 PM
siko7
Honda Civic (2006 - 2015)
Sep 14, 2007 03:56 PM
ccivic
Sep 3, 2004 08:43 PM
DRIVENRacing
Aug 31, 2004 11:09 PM
