control arm help
Old Aug 7, 2009 | 06:09 PM
DOHCED8's Avatar
Default control arm help
so i just replaced the front lower control arms on my 88 crx and now when i accelerate the car like shakes/vibrates violently but stops when i eather push the clutch in or let off the gas.. wth could this be? iv triple checked to make sure that everything was tight
Old Aug 7, 2009 | 06:47 PM
Red_ED8's Avatar
Default Re: control arm help
Its your axels, check and make sure it is intalled correctly. When you pulled your lca did you support the knuckle or just let it hang down? I bet that sucka popped out or is now damaged. I had this same problem on my wifes accord last week after installing a new uca, and tie rod end (and didn't suppport the knuckle :/ ).
Old Aug 7, 2009 | 06:50 PM
DOHCED8's Avatar
i let it hang.. i thought it was the axle, which was bad anyways, and i replaced that and its still doing the same thing.. i just loosend the inner control arm bolts and supported the car and jacked the spindles up and tighten then again. it also vibrates if i turn it to the right while driving
Old Aug 7, 2009 | 06:59 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Did you tighten the axle nut to specs? Could be the wheel bearings, they will cause the same thing to happen, especially if they are not torqued properly.
Old Aug 7, 2009 | 07:41 PM
DOHCED8's Avatar
yea axle nuts are good... if it was the wheel bearing then how come it didnt do it till after i swapped the control arms?
Old Aug 7, 2009 | 08:57 PM
chivid's Avatar
did you bolt up the crossmember bars back to the control arms?
Old Aug 7, 2009 | 10:36 PM
DOHCED8's Avatar
sure did.. foun out the guy that had the car previously used a DA one so i had to get another civic one.. though on the passenger side i couldnt get the radius rod holes to line up with the tapped holes on the control arm with it mounted to the frame.. so i undid that bolt n dropped it back down to put the radius bolts in and i played hell getting the control arm back in the frame mount
Old Aug 8, 2009 | 08:54 AM
chivid's Avatar
theres gotta be something your missing when your virtually inspecting this. put the front up in the air and try wiggling the knuckles and control arms to see if theres any play on them.
Old Aug 8, 2009 | 08:35 PM
DOHCED8's Avatar
so i took it to my friends shop today and rolled it on the rack to get an on ground perspective.. the axle i just replaced is straight, no bends or anything.. driver side axle is all kinds of bent. like if u take the end knuckle and tilt it as far is it will go thats how both ends are.. so im thinking the rotation is whacked out.. changing it in the morning
Old Aug 9, 2009 | 07:13 AM
chivid's Avatar
well let us know if that fixes it.
Old Aug 9, 2009 | 12:11 PM
DOHCED8's Avatar
didnt fix the problem... i noticed that the driver caster is wayyy off.. the wheel doesnt sit in the middle of where it should so thats whats puttin it in a bind.. im in the process of fixing but cant get the radius arm nut off..
Old Aug 10, 2009 | 09:49 AM
DOHCED8's Avatar
got everything swapped out.. even re-put the control arm on and its even worse.. i know its the axle on the driver side.. the one on the passenger side is perfect. the shaft is in the center of both housings.. on the driver side the shaft is at the top of the tranny side housing and the bottom of the wheel side housing.. i cant seem to fix this freakin problem
Old Aug 10, 2009 | 10:22 AM
chivid's Avatar
so the caster bar got busted then?
Old Aug 10, 2009 | 10:54 AM
DOHCED8's Avatar
everything checks out.. the caster is where it should be now and the axle still looks like its in a bind. when i can get a ride im gona warranty out my axle n try putting another in.. it may be a bad axle from the company
Old Aug 10, 2009 | 01:26 PM
B16-CRX's Avatar
let us know cause I have the same vibration problem.
Old Aug 11, 2009 | 02:46 PM
DOHCED8's Avatar
got it fixed.. i swapped out the control arm that i bought for another.. but instead i put the old one back on.. smooth as butter
Old Aug 11, 2009 | 03:06 PM
chivid's Avatar
damn thats good that you finally got that figured out
Old Aug 11, 2009 | 04:21 PM
B16-CRX's Avatar
So bad control arm bushing?
Old Aug 14, 2009 | 03:37 PM
ih8sndq's Avatar
I'm having the EXACT same problem with my drivers side axle. Man, now I'm going to have to try this stuff.
Old Aug 16, 2009 | 10:56 AM
raminas's Avatar
New User
me too, ive already replaced my driver axle and pass. tie rod i know my bushing is bad so im gonna try to replace my upper control arm and spindle and see what happens good thread.
Old Aug 16, 2009 | 07:12 PM
DOHCED8's Avatar
well the only problem im having now is when i try to make a right turn it does it but its not as bad.. its still drivable. in my honest opinion instead of buying new control arms and running into the same problem i did with the length.. just get a set of energy suspension polyurethane bushings n put em in.. that way the length is still the same and ul have the durability of the urethane.. i think thats what im going to end up doing.. find a old set of control arms and just go that route
Old Aug 21, 2009 | 11:14 AM
raminas's Avatar
New User
guess ill be checkin out the scrap yrd or some jap auto place thx
xChrizcrozzx
38
Dec 9, 2016 10:34 AM
unclematt
12
Jun 2, 2016 04:31 AM
97AccordProject
May 1, 2011 05:32 PM
killaj12
Mar 28, 2007 04:11 PM
CuttingEdge SI
Suspension & Brakes
Jan 27, 2005 04:50 AM
