bad axle or control arm ball joint??
Old 03-06-2007, 01:33 PM
killaj12's Avatar
Default bad axle or control arm ball joint??
hi guys
when i drive my 00 civic on slow turns, i sometimes hear a popping sound or click.
its not continuous, usually just one pop, not the rapid clicking associated with a bad axle
it also happens when i begin the turn, as i'm turning the wheel, not midturn.
is this a sign of a bad axle or cv joint?
or is this a sign of a bad upper control arm ball joint?
i know my ball joints are deteriorated on my control arms, and the bushings are going too on my front upper control arms.
i plan on purchasing new control arms next week if that is indeed the problem
but i dont want to spend the money if thats not what's wrong
any help/input is appreciated.
Old 03-06-2007, 02:37 PM
Projekt_2nr's Avatar
Default Re: bad axle or control arm ball joint?? (killaj12)
may possibly be those, but also may be do to loose tierods, common issue.
Old 03-06-2007, 02:42 PM
New User
charjacq's Avatar
Regardless of what it is, you should have it checked! A bad CV would make a constant noise when turning though....
Old 03-06-2007, 03:29 PM
deadline's Avatar
check if any boots are ripped or damage of some sort ?
Old 03-13-2007, 11:40 AM
killaj12's Avatar
could a ripped boot be causing this knocking/popping sound?
i know for sure that my ball joints are messed up.
could this sound be a symptom of this ?
or is this not something related?
i had my axles replaced a year ago btw ...
Old 03-13-2007, 11:45 AM
cjsmuscle's Avatar
Default Re: (killaj12)
If all the grease is out of the rubber boot, it can dry out, causing the noise. I had the constant clicking in turns, and had to replace my axle. The car also shuddered on acceleration.
Old 03-13-2007, 12:33 PM
killaj12's Avatar
it's not a constant clicking like when an axle is bad
its usually just one or two pops/knocks ...
Old 03-28-2007, 04:09 PM
kn4ps's Avatar
sometimes when i turn i get a single knock, i have been told that it means my strut is going bad.
Old 03-28-2007, 04:11 PM
pdiggitydogg's Avatar
thats typically not true...
single knocks while turning or straightening back out usually means bad ball joint
(thanks for bumping a thread thats 15 days old....)
dumbidea
08-20-2017 07:52 PM
xChrizcrozzx
38
12-09-2016 10:34 AM
Peteypablo17
Transmission & Drivetrain
02-10-2013 05:31 PM
jmvtec05
Honda Civic (2001 - 2005)
08-11-2012 09:25 PM
CRX_Control
08-08-2005 03:26 PM
Quick Reply: bad axle or control arm ball joint??
