d16 injectors question
Old Aug 6, 2009 | 08:16 PM
EGed up from the seat up's Avatar
Default d16 injectors question
what is the stock injectors size for a d16 ? also what would be a good size to get for going turbo ? thanks
Old Aug 6, 2009 | 08:35 PM
jake 92eg d16z6's Avatar
Default Re: d16 injectors question
hmmm i belive stock is 240cc`s not 100 percent sure but back to the other question im runnin 450cc`s in my boosted d16z6 they wont max out !
Old Aug 6, 2009 | 08:41 PM
would 350 also work ? i was just planning on running like 8-10 psi. how much are you pushin ?
Old Aug 6, 2009 | 09:01 PM
what turbo are you running im running a t25 garrett runnin 12 psi
and with my mods the car is pushin over 200 horse 450 is your best bet.
Old Aug 6, 2009 | 09:20 PM
i have a greddy turbo kit with a td04-15g i think turbo
nice 200+, i wanna try and push that but we'll see how it goes
Old Aug 6, 2009 | 09:21 PM
92ehatch's Avatar
just get some dsm blue tops.
i have one friend running a t25 with 450cc dsm at 8 psi - dunno what he dynoed at, stock d16y8
i have another friend running a t25 with 450cc dsm at 20 psi - dynoed at 240 hp 235 ft/lb tq d16z6 vitara build
what im saying is, dsm 450's will get the job done
Old Aug 6, 2009 | 09:44 PM
so it looks like im gonna go with 450's then haha
Old Aug 6, 2009 | 10:07 PM
ya its that best way to go
and nice nice the t25`s are good because there is barly and turbo lag
my build is
d16z6
y8 cam out of a d16y8
t25 garrett turbo 12 pounds
turbo xs bov
aem front mount
3 inch dp
straight pipe no cat no res.
450cc injectors
aftermarket fuel pump
V-TEC hahaha
Old Aug 7, 2009 | 06:46 AM
92ehatch's Avatar
my build is
d16z6
turbo xs bov
aem front mount
3 inch dp
450cc injectors
V-TEC hahaha
barely lag is correct.
my friends dyno sheet was 240hp at 3k rpms. thats a fast spool for a 1.6
Old Aug 7, 2009 | 08:16 AM
ya but this winter its going in a garage and either swapped or built
Old Aug 7, 2009 | 08:28 AM
92ehatch's Avatar
what are you planning on using?
i have a vitara build going.
i need a z6 crank and rods to get it near completion
i was gonna get tuner toys rods, but they out of business so eagle it will be.
also, you gonna keep the y8 cam? i heard it is cut on a d15 index and the z6 cam is a better choice
Old Aug 7, 2009 | 08:46 AM
rick_rabies's Avatar
I'm not Rick!
whats the dif between the dsm black tops and blue tops?
blue is 350cc? black is 450cc?
Old Aug 7, 2009 | 07:33 PM
z6 cam is better when i bought the car that cam was already in it if i swap im going b18 but i think im just building it its cheaper
Old Aug 8, 2009 | 06:44 AM
92ehatch's Avatar
blue's are 450cc i dont know what blacks are. they might be 350cc but i really dont know
Old Aug 8, 2009 | 07:12 AM
suspendedHatch's Avatar
D series VTEC injectors are the same part as B series of the same OBD generation (240CC). D series non VTEC and VTEC-E injectors are 190CC.
Old Sep 17, 2009 | 12:57 PM
arankin28's Avatar
New User
the black top and blue top dsm injectors are both 450cc injectors. the difference between the two is that the blue top is out of the dsm 1g turbos and features a single spray style pintle. while the black top is out of the 2g turbos and features a superior dual spray style pintle. the black top is actually better.
Old Sep 21, 2009 | 08:42 PM
FOMULA91's Avatar
Lot of D-series non VTEC are also 240CC... The 180-190CC injectors are used maily on fuel efficient motor like the CRX HF, Civic CX VX...
http://www.b18c5eg.com/injectors.htm
Old May 24, 2011 | 08:53 AM
92 dark knight's Avatar
So which cam is better, the z6 cam or y8? I've heard the y8 cam was cut a few degrees more to create more combustion than the z6 cam. Ive got a z6 right not but thought bout changing the head over to a y8 head. Also the y8 intake is bigger with shorter runners, whats yalls thought on it? just curious on which route to go with
Old Mar 18, 2012 | 07:42 PM
Nick Fequet's Avatar
Icon2 Re: d16 injectors question
just wondering if u can swap the intake out of a y8 fuel rail and all into a d16z6 for my del sol all stock cept i gota stainless exhaust manifold and 2"1/4 stainless exhaust all the way to the back...bought this manifole off wat i think was a y8 for 40$plus i got his valve cover...gd deal or no??
tnx
jfruauff
Sep 12, 2007 11:20 AM
SpecialGoodness
Mar 23, 2005 07:06 AM
Tdawg1030
Mar 22, 2005 10:36 PM
JonGP4
Dec 3, 2003 01:47 PM
