Need help IAC valve
In need of some help, my idle just started to go up and down. The car sat infront of my garage for about a week without being warmed up. Just today, I started the car and once the car warmed up, the idle started to go up and down. It will go up to 2000 and back down. My friend told me to clean my IAC valve, where is that damn thing located on a 1996 Civic DX? How do I even remove the intake box?
Can please someone link me or explain where to go from here.
Thanks.
Thanks.
It should be located on the back of your intake manifold next to the tb. Its got a black solenoid on it and held in with 2 12mm bolts and 2 coolant hoses. I have the same problem my friend told me it was an IACV problem. so imma clean it out see if that works! i have a 99 civic Ex... idle problem!
EDIT: Only after I posted this did I realize HondaSPEC99 jacked the thread. I was replying to the OP who has a D16Y7.
Last edited by BryanM.; Aug 30, 2009 at 03:06 PM. Reason: realized thread got jacked
Cleaning it did not help the problem at all. (I used carb cleaner to clean the screen)!
My idle jumps from 1000-1600rpms with in a second, once car is warmed up... I may just need a new IACV. I checked every vacuum line and they are all hooked up A+... FML this idle problem is going to cost me.
-D16y8 Motor Stock!
Mods
Skunk2 Intake manifold
Skunk2 68mm TB (used stock tps and IACV)
DC Sport 4-2-1 header
Skunk2 Full CB exhaust
AEM Short ram intake
Need some advice ASAP!!!
-D16y8 Motor Stock!
Mods
Yeah i was hoping not to buy another iacv because what if thats not the problem? The only iacv i can find is worth $160, do you know of any shops with lower prices for an iacv???
O and i got that screen lookin bran new and all around it, the 8 seal is in good shape!
idle bounces from 1000 to 1600rpms in a second when engine is warm.....
JDMguyss
13
Jan 9, 2007 07:31 PM
