Suspension & Brakes Theory, alignment, spring rates....
Toe adjustment
Old Aug 5, 2009 | 12:22 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Icon6 Toe adjustment
Went to a local shop a while back to get an alignment. And here are my results:
Left Front: Right Front:
-1.5 Camber -1.8 Camber
1/32" Toe 1/32" Toe
Left Rear: Right Rear:
-.07 Camber -1.8 Camber
-1/8" Toe -1 1/16 Toe
Mechanic said he could not adjust the toe anymore. Can anyone tell me why the toe cant be fixed? And i know its bad to ride with this, its gona eat my tires.
Old Aug 5, 2009 | 12:24 PM
Adnan5224's Avatar
Default Re: Toe adjustment
did you make sure that your end links and tie rods are good? A lot of times if you have play in your toe angle or steering wheel vibrations, etc. its due to bad/worn tie rods.
Old Aug 5, 2009 | 12:30 PM
racebum's Avatar
x2
it's unethical to even do an alignment with worn components.
also, please specify if you mean toe in or out. since machines can rear minus as toe out OR toe in depending on where it's done.
btw, did you type the right rear correctly?> that would basically make your tire tilted having over one inch of toe, you couldn't really drive down the road
if you mean you're 1/32nd out up front, that's great, basically a great street setting
out back. 1/8th in is a little much on the left and the right is just nuts. i'm guessing you would like something around 1/32nd in out back as well
Old Aug 5, 2009 | 12:35 PM
HT Black OPs
i dont have any vibrations or play in the wheel. Im not sure if its in/out just typing from the paper they printed me.
Front: Cross camber 0.3
Front Total Toe: 1/32"
Rear Total Toe: -1 5/32
Thrust Angle 0.94
Hope that helps somewhat. And yes i typed it all correct.
Old Aug 5, 2009 | 12:43 PM
Egezzy's Avatar
Spongebrad Squarepants
it is weird that the "mechanic" didnt tell you what was worn or wrong. i would check the trailing arm bushing.
Old Aug 5, 2009 | 01:14 PM
HT Black OPs
so check the front tie rods? Just the outer? What about the rear
Old Aug 5, 2009 | 01:34 PM
Egezzy's Avatar
rear.
your front is fine. you could have them zero it out if you wanted but 1/32 is within spec.
Old Aug 5, 2009 | 01:44 PM
HT Black OPs
ok cool, and is there anyway to really check the bushing? without having to take alot of parts out? Replacement bushings? I couldnt find any part number on acuraoemparts.com
Old Aug 5, 2009 | 02:00 PM
racebum's Avatar
you should see something. over 1" in out back should have your tire pointed in toward the car HARD. i suspect something broken or worn out since the mechanic said he could not adjust anymore. then again, 1/8th on the left is still a bit much. basically jack up the rear and wiggle and move everything. you either have a bent suspension component, worn out bushings or ? i would call and ask this guy why he couldn't align it. he may have noticed just what we are trying to figure out.
Old Oct 20, 2009 | 12:27 PM
lampshadej1's Avatar
the make adjustable ones, there like rear camber kits kinda, i think password jdm has them
Old Oct 20, 2009 | 12:29 PM
heres the link, there a bit expensive tho
http://passwordjdm.com/PasswordJDM-S...P2491C139.aspx
Old Oct 20, 2009 | 12:54 PM
slowd16y8's Avatar
For that price get the hard race set from special projects motorsports: http://www.specialprojectsms.com/ind...?categoryID=39
Here's cheaper options too
Megan $97 Shipped: http://cgi.ebay.com/ebaymotors/Megan...Q5fAccessories
Blox $71 Shipped: http://cgi.ebay.com/ebaymotors/BLOX-...Q5fAccessories
Old Oct 20, 2009 | 09:10 PM
good ****, i didnt even know about the other ones. PWJDM is way too expensive, for no damn reason,
Old Oct 21, 2009 | 04:53 AM
Egezzy's Avatar
the rear trailing arm bushing will look like an old nerf football. lol. guess that would be the best way to say it. the bushing should have cracks all over the place and even big deep cuts if it is that bad.
Old Oct 21, 2009 | 08:58 AM
Tyson's Avatar
the rear trailing arm is probably bent and run out of adjustment.
thats a huge amount of toe in the rear. its definitely bent.
the fronts are just fine.
Old Oct 23, 2009 | 06:31 AM
JLCivixHBDX's Avatar
sometime you just have to grind the Toe slot a little bit more (oversized)
Old Oct 24, 2009 | 07:08 PM
jimjampants's Avatar
you should scan the print out on to this page. i had to grind my slot in the back out abit but mine was bent i just didnt want to spend more money on a new one. i got mine in and it hasnt been a problem. good luck to you.
wannaBjdmca6
Suspension & Brakes
29
Jan 22, 2011 08:52 AM
00IntegrAllmotoR
Aug 12, 2009 06:48 PM
RallyRedGT-V6
May 19, 2004 04:00 AM
nichols_si
Oct 2, 2003 12:03 PM
01CWITR
Aug 6, 2002 05:32 PM
