do i need coolant lines going to the intake?
Old Aug 4, 2009 | 08:02 PM
jamaicantourist's Avatar
Default do i need coolant lines going to the intake?
on the idle valve, and i think i see two going to the tb? well in jamaica it cant freeze shut, and i start my car and start driving under 3000 rpm immediately, do i even beed the idle valve? lol
im about to change it as it seems bad (revs go up after hard acceleration/launches) and id just cjange the coolant lines to one or block them off, block the ones on the valve, and do the same on the tb...
any negatives?
oops wrong section i drive a 97 jdm itr sorry
Last edited by jamaicantourist; Aug 4, 2009 at 08:03 PM. Reason: wrong section bitches
Old Aug 4, 2009 | 08:08 PM
ek-g6's Avatar
Default Re: do i need coolant lines going to the intake?
bleed idle valve? or do you mean bleed the coolant system? There should be coolant to the tb, then to the iacv then to the water neck.
Old Aug 4, 2009 | 08:11 PM
i was under the impression the coolant lines go to the tb to stop it from freezing shut, cant happen to me, or is there another reason? a sensor
i was also under the impression that the idle valve needs coolant lines to turn down the idle once the engine is warm, i dont really need that...
Old Aug 4, 2009 | 08:15 PM
ek-g6's Avatar
No you dont need the fitv, which is the sensor on the bottom, you can just bypass that sensor, and go directly from intake manifold to the iacv.
Old Aug 4, 2009 | 08:17 PM
i have a 97 i dont think i have a fitv i think its just a iacv OK i got it mixed up i though the iacv does what the fast idle valve does... hmm. what exactly do i need coolant lines to the iacv for then? lol
Old Aug 4, 2009 | 08:23 PM
ek-g6's Avatar
Coolant tells the sensor that its warms, and thus making your car idle. Fitv controls the idle during start up, but IMO i dont think you need the fitv.
Old Aug 4, 2009 | 08:32 PM
ok so the coolant lines on the iacv will stay, lovely, ahhhm still not sure if i have a fitv i read its 96 and under have them but ill check i think i see hoses going to it, ill bypass them
Old Aug 4, 2009 | 08:36 PM
ek-g6's Avatar
all civic and integra have them i believe? its under the throttle body and the obd0 is on the intake manifold.
lude98SH
Oct 29, 2006 03:17 PM
GAccord
Jan 29, 2005 10:18 AM
slowone
Jan 24, 2003 05:39 PM
dinosa21
Nov 27, 2002 01:22 PM
X2BOARD
May 17, 2002 12:57 PM
