egt probe install
Old Aug 4, 2009 | 04:03 PM
thegatekeeper14's Avatar
Default egt probe install
would it be okto install my prob in my #3 cylinder exhaust runner, pre turbo? if the car is running
Old Aug 4, 2009 | 05:06 PM
tepid1's Avatar
Default Re: egt probe install
That's where it is suppose to be.... about 1.5 to 2 inches from the exhaust flange in the runner.
Old Aug 4, 2009 | 05:20 PM
can i install it onthe car while it is assembled
Old Aug 4, 2009 | 06:00 PM
downest's Avatar
Are you asking if you can install it while it's running?
Old Aug 4, 2009 | 06:16 PM
tepid1's Avatar
Yeah you can, but it'd be pretty dumb.
Old Aug 4, 2009 | 06:56 PM
yeah, my friend did it on his diesel truck while it was running, i was just wondering if the small metal shavings that did fall into the exhaust if theyed flow threw the turbo
Old Aug 4, 2009 | 07:04 PM
tepid1's Avatar
What I've done in the past is when drilling or tapping is to put some grease on the bit so the metal flakes stick to it instead of going in the manifold.
Old Aug 4, 2009 | 07:38 PM
boostedb20z's Avatar
i would never run a egt probe per turbo what if it brakes off??? there goes your 1300 turbo
Old Aug 4, 2009 | 07:53 PM
tepid1's Avatar
When was the last time you saw an EGT probe break? I work with TC and even RTD probes all the time and have yet to see one break. lol
I myself have 4 egt probes.... one for each cylinder.
Old Aug 4, 2009 | 08:10 PM
RC000E's Avatar
An EGT probe break? I haven't thought twice about putting it in front of my GT30. I've never heard of an EGT breaking off.
I've drilled DSM mani's several times pre-turbo. Used grease on the bit and had the motor running...no problems ever.
Old Aug 5, 2009 | 12:26 AM
downest's Avatar
I've seen them break off in Subarus before, as well as their pre-turbo cats.
Old Aug 5, 2009 | 05:38 AM
migs's Avatar
It depends on your EGT. The above fellas state 1.5-2" away from the manifold flange. I have an AIM sports and it requires 6" distance from the flange, on cyl #1. What EGT do you have? Whatever it is, follow those directions.
Old Aug 5, 2009 | 06:26 AM
tepid1's Avatar
That is dependant on the type of probe. Theirs might not be able to handle the stress....
Old Aug 5, 2009 | 06:45 AM
DESTROYER's Avatar
Why are you guys drilling and tapping an EGT probe while the engine is running?
Old Aug 5, 2009 | 07:51 AM
Frankenstein_VW's Avatar
... I'm wondering the same thing
Old Aug 5, 2009 | 08:17 AM
Bakeoff's Avatar
I think running = assembled....?
Old Aug 5, 2009 | 08:53 AM
chrisbmx68's Avatar
i think running = running so that the tiny shavings of metal can be expelled through the turbo gradually instead of a pile of them building up then getting slung all around when the motor gets started up.
Old Aug 5, 2009 | 10:54 AM
srmofo's Avatar
I would think that since it is pre turbo, there is a bit of back pressure in the pipes...so when you punch through it pushes gases and metal shavings out of the hole instead of allowing them to fall in........I still dont get it though, we are talking about a honda right? It takes less than half an hour to pull the manifold off, and not risk ANY metal going through the turbo
Old Aug 5, 2009 | 11:19 AM
1/2 an hr? hah! not in a DA with a topmount. = no room!
Old Aug 5, 2009 | 11:35 AM
RC000E's Avatar
Of course personal preference is to remove the manifold. I certainly removed mine. Fact is though, it's very common practice in the DSM world. A lot of those guys run stock manifolds, yet do various mods (MAF hack, boost controller, afc, etc) and adding an EGT is something they'd like to do, but don't want to deal with galled bolts.
Therefore, yes, with the motor running, drill the port with some grease on the drill bit. Between the grease grabbing shavings and exhaust pushing them out it's pretty safe. Would I do it on DSM's with 14b's..yes, and I have...would I do it with my GT3082r downwind..hell no. The risk is low, but when CHRA's are 1000 bucks low risk isn't low enough.
Old Aug 5, 2009 | 02:49 PM
srmofo's Avatar
^ thats my point, I can see on a diesel or something similar, but cmon....even if it is a topmount, its still a honda.....
Eckz2k
Jul 17, 2003 04:41 PM
civic1990si
Jul 3, 2003 09:20 PM
2camsaam
May 6, 2002 07:19 AM
turbocoupe
Oct 22, 2001 09:47 PM
